How to make an overcoil
Very impressive. I don't imagine it could be done without the special tweezers.
The times I've had to tweak overcoils has given me real problems - resting the tips of the tweezers on the surface risks damaging the "flat" coils. That's how I trashed one hairspring, by realising the tweezers while the tips were still in the coils.
Maybe it's possible to slide a thin bit of plastic under the overcoil when working on it ?
It can be done without the special tweezers. I don't make overcoils very often, more likely I might modify the overcoil curve to correct isochronal error, and it's quite rare for me to dig out the special ones in either case. They are nice to have though.
When modifying the coils, what is your technique, do you have the tweezers hovering in the air above the lower coils?
Yeah, pretty much. I'll grip the overcoil somewhere with one pair, then tweak with another where I want to modify the curve. This is with the spring off the balance. In the watch, if space permits, you can often do a lot with just one pair of tweezers- in fact one of my hairspring teachers pressed on us that it's always better to use one pair if at all possible; when you get two going you can mess things up very quickly. Out of the watch you need a second pair though.
How many hairsprings did you have to go through while learning this? Working on hairsprings while the hairspring, balance wheel, and balance cock still in the movement sounds very difficult! Sounds like everything else will be blocking your view!
I often tweak the terminal curve whilst the balance is in the movement. I can sometimes adjust the flatness of the spring using a fine oiler to get under the coils - depending on the access.
As @nickelsilvernotes, your are less likely to do damage with one pair of tweezers.
We learned in school, starting with huge alarm clock hairsprings, working down to small ladies size springs. So actually didn't destroy very many. The teacher would put in bends in the round, we'd correct, then bends in the flat, correct, then both and several of them. For some students it was hellish work, but in the end everyone became very competent.
I would say 90+ percent of hairspring work gets done with the spring in the watch. I adjust probably 2 out of 3 springs that pass through my hands, pretty much always in the watch. Exceptions would be if I need to true it at the collet, or if a spring is severely out of true (mangled). Truing at the collet is done with the balance held in calipers (there are specific ones for truing springs), and mangled springs will come off the balance and brought back to shape, then trued in the watch.
I did destroy the hairspring on a ladies Omega 455 movement I have. At about 3.5 mm diameter, even my finest tweezers seemed massive. The more I tweaked, the worst it got.  One day I hope to find a (cheapish) replacement balance, but I've been searching over a year.
I think a spring that size would get even your full attention !
Just dug it out for another go, and managed to get the tangle out - it's looking a lot better. Maybe I will have a chance. Problem is the metal is VERY soft. A couple of bends in one place will snap it.
Edited by mikepilk
Hi Mike
 I too  find soft spring difficult to work on. I can imagine a overcoil to be more challanging to shape on soft springs.
Not a bad record if you have only destroyed one overcoil , hate to have to show you my bin.
57 minutes ago, Nucejoe said:
Hi Mike
Fortunately this isn't an overcoil, but as you can see from the scale in the pic, it's tiny !
43 minutes ago, Nucejoe said:
Special tweezers No 9, is adjustable for spring's thickness and bent up .
We had various discussions about hairspring tweezers in the past. It's always worth to mention for the casual reader that these are not made anymore, one can possibly find some NOS pieces but beside the extorsionate price, only the tiny sizes are offered, not meant for men watches.
This is a great video.  I found it awhile back and watched it but it was good to see it again.
I have to do this on my Cyma hairspring but I do not have the bending tweezers (either one) so I guess I will use the technique I saw on another video where the hairspring is held tightly with a tweezer and pressed into a block of wood.  A little scary...but...
I used the technique with a block of wood to flatten a bent spring - it works really well.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
    • for the most part no. Each individual watchmaker and/or shop had their own system. One of the shops I worked at basically had a reference to a page number in a book. then there are some shops that do no markings at all as they keep their records on a computer and they don't have to mark the watch. Usually if somebody is marking and they've service the watch before you'll see those next to each other. then as far as anything resembling a standard goes at one time the American watch and clockmakers Institute assigned all of their members a number. but that was a very long time ago and I doubt that they are using it anymore.
