Balance staff removal
It started well. Got the clip off, cleaned in B-dip, bit of grease, then ping 😫. Lost the clip trying to refit it. I'll get a replacement from eBay.
I used Google Lens on the pic and it suggested "motorcyle belt punch". And googling pics of that does show very similar tools. The end on mine is sharp, and does look suitable for punching holes in leather. I've no idea what belts on motorcyles would need piercing? The hole is about 1/4", so I cannot see a use in watchmaking. So, why have we both found one in a collection of watchmaking tools?
You often see the term used on old watch part boxes. Staffs for bracelet watches, timing washers for bracelet wstches etc. -
Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
