Steve, new to this site
Stelen
Hi, my name is Steve, I live in Wales. I did Marks course last year and have doing watch repair and servicing of my own watches
I was given a watche by a friend to service, this is a Rubelin and Graf, which I believe is a Chinese movement. After stripping the movement one of the incabloc springs was broken. I went onto Cousins uk. After looking at the springs they have, which always refer to a movement number or type, I am non the wiser. I have measured the jewel and the housing but cannot make sense of the numbers could anyone please help with determining the size and or how to correctly measure for the correct spring.
Hi Steve, I have yet to encounter an Incablock shock setting in my very short journey down this road. I've also been waiting days to be allowed to buy at Cousins. I never even suspected that those tiny springs came in different sizes.
So - I'm of no help to you but welcome to the forum!
I'm in the middle of Mark's level 2 course and have a bunch of movements but I've been waiting on a mainspring winder.
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
Is there a cal number on the movement? Some good photos would help. If there is no cal on the movement we need photos of the keyless work side and a photo of the incabloc. Give us as much info as you can.
    • Mark keeps a close eye on his forum. I'm sure if you asked him he will reply, he might not do it right away but you will receive his answer.
    • I kind of think the same, the surface under the oil is the same as the surface around the oil. Can epilame both repel and attract , that doesn't quite make sense in simple terms, but is it more complicated than that. When cohesive forces within a liquid are stronger than the adhesive forces of a surface then surface tension is high causing the liquid to bead up. So  an applied epilame coating reduces the adhesive force of a surface inhibiting a fluid to wet the surface. So i guess no epilame cannot both repel and attract . If something is keeping the oil in place on top of an epilamed surface then there must be another reason for that.
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
