Anyone paints dials, or knows someone?
ALS
Hello!
So I am kind of just getting into this hobby, and I found beautiful ~1912 gem from auction. It's Omega's pocketwatch, and from what I found on internet, I think it's 19 cal. movement. Did not really know how to tell because it has only serial number (4100990) and 4 digit number (0990) on the underside of the train of wheels bridge (third picture).
  Anyway, there are some small tweaks to fix, like the ratchet wheel has worn so much, that if has holes in it (first picture).  Those spare parts are somewhat easy to get, BUT that dial has worn really not too beautifully, ink has started to spread, and it just wipes away with cottonstick. I have seen some kind of dials on eBay that might fit on this watch, but I am feeling that I want to keep this one, because it is so unique in color, and pattern in the middle. I was not able to find same dial anywhere and that is good and bad thing 😄
Now getting to the main point.
Any of you paint dials, or know someone who does? As I am just starting this hobby, so that means I am also kinda on budget, so I cannot lean on any one too professional 😄
Edited by ALS
2 hours ago, grsnovi said:
I have no idea what it will likely cost you (or what it may be worth to you) but these guys seem to do amazing work. I think there's also somebody in Texas that does dial restoration.
Damn, atleast on that site, the price starts with 100 pounds for cleaning the dial and repainting and I am guessing repaint works only if they have good enough reference point. And the price does not seem horrible for the job. But I think it's too much for my wallet.
3 hours ago, grsnovi said:
You have to admit their work looks great.
Indeed! Those look pretty flawless, what you can inspect on the site.
9 hours ago, Nucejoe said:
Same is done for much less in India.
Contact on ebay them Indian selling watches with painted dial.
Good luck
I don't know why, but it feels kinky and risky at the same time to send the dial to Indian guy from eBay 😄 but I might atleast give look at it!
Good luck
My thoughts exactly. If they would only concentrate on doing dial refurbishments and breaking down watches for their parts, instead of trying to pass off some hack job as a working watch. 🤬
6 hours ago, LittleWatchShop said:
Two dial refinished I have used in the states. Kirk Rich, and International Dial. Expect to pay $100 to $200.
Many years ago, Southern Dial in Dallas, but they are no longer in business.
Well the price doe's not seep too bad, but what i decided to try, is sometihng new :D. I asked one friend of mine to desing and cut with lazercutter he has, a watch face on masking film. Plan is to try paint atleast the main numbers back myself.
  • Similar Content
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
