BTCo movement?
Hello again.
I believe I have found the name of the movement of my project. BTco
Does anyone have any knowledge of, or knows where parts can be purchased. I need a barrel arbour (screw snapped at head).
I have attached a photograph of my movement, and an internet information of similar. The keyless works are the same, but on opposite sides. (negative reversed?) any advise ofr help would be appreciated.
Regards
Ross
 Thats Beguelin watch company, they owned the Damas brand and I have seen their movements in Galo watches plus a dozen other companies, also supplied parts or movements to Rolex.
Have you check julesborel.com?
Regds
I've looked on the site.
As you can see, the movement that I have (top image) is the exact reverse of the original on the experts site (bottom image). The expert from the site I contacted, says they are are not the same make. Back to the drawing board.  He also said the only way to get a barrel arbor is to obtain donor movements. The Arbors may, or may not be compatible. Suggests I try to remove the broken screw.
I think that s my best option. I'm going to try to make a groove and attempt to screw the broken shaft out.  Attaching a photograph of the arbor. Awaiting a set of fine files. Wish me luck.
Regards
Ross20220425_181954.thumb.jpg.d946381ad59ccad01e908ede2b6027e9.jpg20220425_182007.thumb.jpg.7e06cc8fb817adc33b1005c6a46d704f.jpg
Edited by rossjackson01
copy photograph removed
Well, parts of it are similar (but not exact). It would likely be good if you knew more about your movement so you could find an identical donor. One advantage of going with a known "brand" I suppose.
I'm still in limbo on my Elgin 313 but I do have a second (which I'm likely going to have to cannibalize to get one working - not sure which one t will be yet).
Did your movement come out of a case or did you just get a movement?
Have you posted an image of the other side?
  • 9 months later...
More advice please
I'm progressing with my skills and now feel able to attempt restoration of this family piece. When I first started with the wonderful hobby, I jumped straight in and disassembled this old watch without knowledge. I created a problem in that I over tightened a screw into the arbour of the mainspring barrel. The head has sheared off. Maybe it was the left hand threaded screw, not sure.
I would like to attempt now to remove the offending screw thread. I can't drill. Don't' have the skill or equipment. However, I have become aware of the use of Alum powder to dissolve the metal. I would like to give it a go.
My question is this. Looking at the pictures, does anyone think that the arbour is of the same constituent as the screw? If I try the Allum, will it dissolve both items?
Thank you in anticipation.
Added information. Looked thought the content of the watch parts. No left hand thread screw.  Bummer!
Regards. Ross
more information
Hi Ross Unfortunate indeed, The use of Alum powder to dissolve steel is useful knowledge but a steel screw in a steel arbour will only lead to tears.  There are broken screw removers sold by Ali Express  (similar to if not the same as Bergeon) which are inexpensive.  Yes its another tool to the armoury so hide it from the wife. But a bit safer than freehand drilling. Attached is the tool in question.
I've joined AliExpress. Yes it is cheaper than ebay.  The drill is now in my 'wish list'. It does mean that I now need to source a left-hand threaded screw with a large flat head. No one seems to sell left handed screws. Very odd.
I have to confess to being somewhat confused by this tool as to me it looks like someone has seen a picture of the Bergeon tool, tried to copy it, and got it wrong.
The Bergeon tool only works on through holes and works by clamping the broken screw between two toothed bits as shown in the pic.s1517_dia2_cymk.jpg.e7963619fe5d738ecfa981a63ff69e8a.jpg
This holds the screw still whilst you rotate the part around it to unscrew it. Because the gripping force is between the two bits the friction between the screw and the part is not increased.
It doesn't really work very well on blind holes because you can only push on the broken screw from one end, which forces the threads on the screw against the threads in the part, increasing friction and making it more difficult to turn. Add to that the fact that the part would have to be pressed tight against the tool frame which would make it impossible to turn anyway.
Given that most (if not all) arbors are blind holes I don't think that even the Bergeon tool will help in this situation.
What puzzles me about the Ali-X tool is that the supplied bits appear to be twist drills, suggesting that the tool is used to drill out the damaged screw. However for that to work you would need to be able to rotate either the part or the drill, and there doesn't seem to be any way of doing this. There doesn't even seem to be any means of holding the part.
I suppose that it would still be possible to use the tool the same way as the Bergeon on a through hole with a drill bit  pushing into each end of the broken screw, however I doubt that this would be as effective with the tips of the drills being designed for cutting rather than gripping.
Either way I don't think that either the Bergeon or the Chinese "copy" is going to be very helpful which a screw broken off in a blind hole. The best way that I have found to remove the screw in these situations is to clamp the part in a vise with the hole pointing up so that I can look down on it, preferably though a microscope, and then using two fine sewing needles to apply a turning force to what ever topography the top of the broken screw offers. Providing the other end of the screw hasn't bottomed in the blind hole causing the threads to bind this should work every time.
    • The UK lots can be a 404 hit or miss, 6 - 10 watches can come in anywhere from 20 - 50 quid. I once had a 404 division of 8 watches for a fraction over 30 quid, one of them was a Smiths Astral model National 17 an absolute certainty for winner contender. The crystal was scrached up to the point of being very difficult to see the brand, something triggered a gut feeling in me and it paid off.
    • I just picked up this Mondaine quartz watch on tradera.com for £11. It's a non-runner so I will replace the Ronda movement (£10.95 at Cousins), polish the case, replace the case-back gasket, and replace the mineral crystal. Now, the problem is finding a suitable crystal. The original crystal is slightly domed (2.4mm thick dome), measures 36.4mm in diameter, and is 1.3mm thick at the edge. The closest I can get on CousinsUK is 36.5mm in diameter, 3.1mm thick dome, and 1.5mm thick at the edge. I think the replacement crystal would look OK, but the problem is finding a suitable glass gasket. The case diameter for the glass gasket is 36.9mm and the closest glass gasket I can find on CousinsUK is either 36.8x36.0mm or 37.0x36.2mm. I guess one of those glass gaskets could work but as you can see there's no way the 36.5mm domed crystal would fit the inner diameters of those glass gaskets. I guess I will have to give up on a domed crystal, no? So, the backup plan is to use a (1.5mm) thick flat mineral crystal as the diameters come in increments of 0.1mm. But, what glass gasket would be the better option? The one with an outer diameter of 36.8 (0.1mm too small) or the one with an outer diameter of 37.0mm (0.1mm too large). Again the case diameter for the glass gasket is 36.9mm. I believe I read or heard that the crystal diameter should be 0.1mm wider than the inner diameter of the glass gasket. Is that correct? I'm sorry for all the numbers. I've tried to make it as clear as I could. So, I'd appreciate your thoughts on this. BTW, measuring and sourcing crystals and gaskets is extremely time-consuming! 😓
    • Lots to choose from... Just sayin'.
    • New one on me too.  Is that corrosion on the crown wheel?  Let us know how you get on.
