Another Incoming, Vintage Chronograph!
New one on me too. Is that corrosion on the crown wheel? Let us know how you get on. -
By eccentric59 · Posted
Case in point, I just scored a lot of 4 Timex mechanical watches for $15.50 which puts the individual watches at $3.88 each, or £3.09 (or €3.59, ¥28.08 (CH), ¥607 (JP), ₹324 ... or 0.00006 Bitcoin ) 😉 -
The 73 was my setting lever make Mike, same piece fitted to your 72. I enjoyed working on the movement, fair quality. 73 wasn't front loading,but a tight spacer ring that i had to fit onto the movement before casing up. I had to adjust endshake on the third wheel so apart from the make everthing else was good.
