ETA 2789-1
5 hours ago, rossjackson01 said:
Wow! What a learning curve. 3 strip downs. Could not get the wheels to turn. Finally, after watching a video a number of times I realised that I was not getting the click to be operated on the crown wheel which is on the barrel spring. I had just been placing the crown wheel onto the barrel. No adjustment to make the click operate. Aagh! All the videos of this particular movement are accompanied with music. No verbal's. Got there. The main spring now winds. I can move the Pallet fork and the escapement operates.
As a novice. It is such a sense of achievement. Felt I had to tell you all. Sorry to be a bore.
Regards
Ross
We’ve all been in that position. The sense of excitement is out of this world… as well as the feeling of dread when a part flies off and you spend hours on your knees searching for it on the floor.
The first day of my watch repair, this watch, I lost 2 items. My bride found them 2 days later.  To overcome that problem, as a result from a comment from a member, I purchased a small plastic container from a local supermarket. Spent a few minutes cutting out the front, leaving a lip. I used an old laptop case as the base.
Since install, I think I have have in excess of 20 'pings' on the side walls. A frantic look in the box has been successful on every occasion. Whew!
I also place every item in small containers.
I don't have much space as can be seen. Tools by the computer, watch box against the wall. I store the working box on the printer when not watch repairing. I can look at the computer when repairing. Thank goodness for YouTube.
Thank you to all
Regards
On 3/2/2022 at 4:57 PM, rossjackson01 said:
Looking a the cog part at the top. I notice that the cog does not actually sit in the gem. It looks flat at the top. Is there supposed to be a point?, that inserts into the gem.
EDIT: Oops, didn't realize I wasn't on the last page...
Absolutely! The pivot has been broken off (sensitive little buggers, oftentimes only having a diameter of about 0.1 mm) You'll have to source an intact escape wheel.
Edited by VWatchie
VWatchie.
Done as suggested. Twice. Inexperience ruled.
Regards
Ross
Well, this watch keeps giving, NOT.
I can place the balance and bridge into the pivot. After gently touching, It oscillates very slowly, about 3 per second, and only to 120 degrees. I tighten the screw and it stops.  Been at it over 2 hours. Any comments would be appreciated.
Thank you
Ross
Sounds like there is no end shake on balance staff ( staff's axial end play), in which case end stones push on pivot ends and stop the balance.
Try shimming up the cock to create some end shake, ideal end shake is .02mm or less not including zero.
Thank you Nucejoe.
Does that mean, in layman speak. A shim of metal should be inserted under the balance bridge to raise it. Can shims be purchased? Could the shim be, a piece of an old spring, a washer?
Thank you in anticipation
Ross
6 hours ago, rossjackson01 said:
Tried a shim. Did not work. When bridge is place, tightened or not, the balance only spins for about 30 seconds then stops. I have tried 3 pallet forks. Same thing with all.
Depressed
Ross
Could be a bent pivot then.
Hi Ross to eliminate the rest of the parts remove balance and fork and check the train is free, then fit the fork and add a bit of power is the fork flipping from one banking  to the other when moved, it should be a snap action if ok fit the balance and re try if same remove balance and fork and just fit th balance and puff with the blower does it move freely and oscilate for some time, If so we are looking at checking the balance spring for  concentricity and flat ness and also for the beat error. If its a long way out it will never start.  with no power on the watch check the alignment of the fork , inpulse pin and the position of the fork between the bankings. I should rest in the center.
Do you mean " the balance spin for 30 seconds"   or movements runs for 30 seconds then stops.
My take was , when you have only the balance&cock on the mainplate.
If the movement runs for only 30 seconds, its what weasol says.
All wheels work freely. Everything seems free. Movement runs. 30 seconds then stops. I noticed that the balance hairspring seems to be 'touching' when oscillating. I touched the balance surround with my tweezers. The movement ran for 1 hour then stopped. I touched it again and it has not worked since. The hairspring looks 'wrong'. Lack of skill appears to have knackered the balance. Don't have the skill to repair the balance. May have to delay any further work until I can get a replacement part.
I'm getting really good and wrecking balances and escapements.
Not stopping practicing though.
Regards
Ross
Edited by rossjackson01
grammar
It's not often you lot are wrong. BUT YOU ARE RIGHT AGAIN. The balance wheel was not revolving. I removed the bridge and notice that the 3rd wheel did not connect with 2nd wheel. I have stripped down the train of wheels and will start again.  I still think the balance is not OK as it does not rotate.
Ross
Hi Ross when you get the balance out post some pictures of it top bottom pivots and the spring its self, good man for finding the fault with the train,we are nearly there now.  when you put the train wheels and bridga on check the rotation ie ( with the watch minus the fork) put a couple of turns on the spring, the wheels will run down and the ecsape wheel will reverse a little at the end. Once accomplished then fit the fork and check its action must be snappy under power, then the balance goes in.  If you wish before the fork goes in fit the balance and give it a puff of air and check the rotation and the contricity and flatness of the spring in the free state.
I have one of these movements in my collection - I wanted one as it's a "high end" ETA movement.
I was surprised at how "flimsy" the movement is compared to other ETA models - the mainplate and bridges seem much thinner, than say as 2836.
My movement had signs of someone heavy handed having a go - the mainplate was distorted in the centre.
Have you checked that all the bridges/cocks sit correctly and the gear train has sufficient endshake throughout  ?
Ticking, ticking, ticking, ticking, ticking ....
Thank you, Thank you, Thank you.
You are not going to believe it. When I damaged the escape wheels (yes, plural), I obtained replacements which included a pallet fork. I used these new pallet forks. They were the problem. The replacements were for an ETA 2789. Supposed to be identical with the ETA 2789-1. They're not. I put the old pallet fork with the replacement escape wheel. Still ticking in any position. Woohoo!
Job tomorrow is the calendar side.
Congrat Ross.
 The two movements differ in complicarions only, thence the thickness and so on.
I bet pallets of the replacement fork needed adjustment, the old one worked  because it was already adjusted.
  • Confused 1
Adjusted? How is that done? Not being churlish. Genuine request for information. They appear so small. At this time of my learning cycle I am genuinely interested.
Regards
Ross
Regards
 Its about moving pallets inward and outward in the fork slot, so to optimize  the  impulse  deilvered to the impulse jewel.
 There has been many discusion on the subject with pictures illustrating details, with Swiss lever the need for adjusting pallets is significant, the task involves dealing with the" lock"  run to the drop " and " drop"  at the right instance, also  issue of overbanming is of concern.
I'd say at this point you best practice with clean&lube and regulating of a movement, hopefully you will soon be ready to step in the mind field called pallet adjustment.
Regards
Nucejoe
Thank you for your kind comments. I think that pallet adjustment will be light years away for me. I ordered my first tools on 17 December 2021. Youtube was my lesson forum until January 2022 when I opened my first watch. All the watches I purchased or practiced with, were like this one. In need of repair. Parts broken. As a novice, it's been a high, slow, learning curve. But ever so enjoyable..
And... today I actually felt that I archived the accolade accredited in this forum. I'm a 'Watch Enthusiast'. Woohoo!
Regards to you, and all who have assisted.
More update will follow when I carry on tomorrow. Youtube rules! Really looking forward to it.
Ross
    • This is a flying cutter, usual one. The cutter itself is shown in the pictures in the first message, it is made of broken tungsten carbide drill bit. I asure that all the angles of the cutter are as they should be. I have video - little older one - that I made when onse making the same kind of winding pinion for a Poljot 2200, which is even smaller than this one. It is not easy to see in the video, but the tool rest moves about 1mm towards the object in Y direction and then returns back untill cutter is rotating. Then the spindle is rotated one tooth ahead and everything repeated untill all teeth are cut.
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
    • Why cut the paper, cut a square around the image and grind to it.
