I was looking at this mainspring winder set which is for sale.  Does anyone have any experience with these?  Will they handle most wristwatch sizes?  I am trying to get the model number to see if I can find any more info regarding these.
Cheers!
Roger
Sometimes it will be a tight fit. But if it looks like the spring will break then don't use it. Sometimes you can use the next size down crank with the correct size barrel if you are careful.
Omg. I only have one size partly because i buy it separately and not the whole set. So you reckon what i should do is to exchange with the watch shop that i bought from to an appropriate size? Thanks :)
But sometimes the arbor does not fit the mainspring for the correct size barrel and/or the other way round so it is useful to have a set - but even my set with 17 barrels both left and right hand cranks will not fit every mainspring/barrel combination, but the more sizes you have, the more chance you will have that you will have a correct combination.
Cheers!
Roger
Unfortunately, I lost the opportunity to buy the Watch-Craft set shown above.  Has anyone used the K&D 127 or 128 Mainspring Winders shown below?  Will both do wrist watches (I am not working on pocket watches)?  Any insight would be appreciated.
Cheers!
Edited by 64americandeluxe
Here is another set that I am looking at (see below).  Any advantages or cons to using the KD 126,127 or 128?  It looks like the only difference between the 127 and 128 are the barrel sizes they'll accept.  The 126 is the "Robbins Type" but I am not sure what the significance of that is.
Thank you!
Roger
Oh.. anw for some mainspring i managed to fit into the mainspring winder. But when i wind almost gonna complete it and it suddenly pop up and broke the mainspring. Why is that so? Am i doing something wrong? Do i need to flip the mainspring and put it into the mainspring winder? And sorry for this question does flipping the mainspring will causes anything? Thanks.
Hello. Watchcraft mainspring winders can be used to wind right hand and left hand so they are a good starter to begin with. Some mainsprings are left hand wind or right hand wind so the Watchcraft will work , but they are not the quality of a set of Bergeon winders which come in right and left hand wind sets or combined.
I find the most K&D's winders are ok for pocket watches but not all of them fit most wristwatch barrels.
Excellent information!  Thanks very much!
Roger
Not quite certain what happened from your description.
Thanks. Im not sure how to put it in a way. Anw, i will try my best and figure it out and share my success story down here. Thanks. I roughly have the idea of how to..
  • 5 weeks later...
I ended up buying a Watch-Craft winder set like the one shown below.  I should be trying it out in the next week or so.  I know the learning curve is rather steep.  Fingers crossed...
Cheers.
Roger
Hi I was just looking at mainspring winding tools and as someone who is new to this think they are a big expense for the new coming is there anther way of putting in a mainspring with out the tool, or do new springs come ready to fit ?
To be done correctly and more importantly Safely...you really should use mainspring winders to fit mainsprings. There are instances where they are not needed, when the mainspring is held with a girdle that is smaller in diameter than they barrel. These can be installed directly into the barrel from the girdle. But, then again, I usually remove the girdle and inspect, clean and grease the mainspring before installing it. So, I still use a winder set.
There are some deals on used sets out there but I've bought poor sets along with really good sets. It's hit or miss, to be honest!
I bought a used set of Watch-Craft mainspring winders for wrist watches recently and they were very reasonably priced.  I used them for the first time this past weekend (first time ever winding a mainspring) on a mid-1960s Elgin and found the experience quite easy.  I installed and removed the mainspring about 3 or 4 times dry to get the hang of it and then oiled it and reinstalled it.  With the winder, I found the removal and reinstallation of the mainspring much easier than I was expecting (many comments online left me apprehensive about doing this but I was very eager to learn this aspect of watch repair).  For me, winding and installing the mainspring back into its barrel was much easier than trying to align the three pivots on the train bridge!
Cheers!
Roger
  • 4 weeks later...
I'm looking at getting a mainspring winder, the likely candidate being the Bergeon 5355 there's not a lot else thrown up in searches but before I commit is there a better alternative? Occasionally people can recommend a genius of a Chinese alternative to things...
Lee
I have purchased cheap mainspring winders in the past and they have been terrible. In the end I plumped for the 5356 Set. It serves both left hand and right hand mainsprings. But I find mostly that I use sizes 4, 5, 6, 7, 8 and 9
Most swiss movements use the clockwise wound handle and cranks and I find the anti-clockwise handle and cranks useful for Japanese (like Seiko).
There is a special ETA set, but I find #8 is OK for the 7750 and using size #7 with #6 crank (carefully) works well for 2892-A2 and 2824
The rest in the set I rarely use.
  • 5 months later...
So, I'm on the market for a set of mainspring winders and I had a few questions. The main options I can see, in terms of second hand or used, winding tools seem to revolve around:
1. Watch-Craft Bracelet Winders: Sets of 8 in sizes 5mm to 10mm.
2. Bergeon 2729 Winders: Single handle; set of 7 barrels in sizes 0 (5.6mm) to 6 (9.8mm).
3. JC Schilling Bracelet Winders: Much the same as the Watch-Craft ones.
4. K&D 123/128 Winders: Set of 7 barrels and bench vise base. Their sizes tend to be vague but the 128 seems to start from 8mm.
I suppose the worry with 1-3, is how likely is it to need anything larger than 10mm, and how to deal with any left handed mainsprings? Any recommendations or advice? If it helps, I intend working on vintage watches which will primarily date prior to 1970s, so I'm hoping the 10mm upper size on most of these is not an issue for a beginner green looking newbie like me ;).
At present, leaning towards the Bergeon though the Watch-Craft's are more readily available from the US (which makes them more expensive as it happens if you throw on customs + VAT).
Then again, I just spotted a Bergeon set that went for close to £260. Seems the Watch-Craft are a fair bit cheaper overall... Checking the non-local ebay sites to find a few more samples. Looking at older forum posts elsewhere, the prices have gone up in the past year or two for used winder tools.
Edited by PadraicB
I have a K&D winder but do have problems with small watch springs. Releasing the winding notch from the newly wound spring can be troublesome & I have destroyed a few with this problem. It might be because it is an old vintage one but I think it is just the design.
If my finances improve hope to purchase a Bergeon or at least a barrel type winder they seem to offer a lot less hassle.
I don't know guys but in my case I've been pondering about winders and although it would be nice to have a good quality set, the volume I handle doesn't justify the expense therefore I always do them by hand. Somehow it keeps me "closer" to the watch! :)
It is good to know about the K&D glitch, clockboy, since I've spotted some on eBay occasionally and I've been tempted!
I am on the look out too for a set, finances permitting. Anyone want to upload a video of hand winding one and what to or not to do?
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
