Hi folks and Happy New Year!
Does anyone have any ideas in how to prevent surface rust from forming on stakes or even the staking anvil dye table? I have a really nice Marshall set as well as K&D. Both fully complete and in excellent shape but the stakes (especially) quickly develop rust. EvapoRust helps... for 2 weeks or so. Same goes for my octagonal anvil. Is there a trick to keep these things rust free? I’m sure when they were new, the original owners didn’t have this problem for some time.
Thanks for any input.
Marek
Hi  you can use moisture absorbents such a silica gel crystals often found in small packets when you buy power tools etc, they are available on the ebay in manydifferent  containers  Isuspect you would require the small dessicant sachet's to put in the box with the staking tools.
Apply a thin film of oil with a rug all over, place a silica-gel bag in the case, store in heated, low humidity environment.
1 minute ago, jdm said:
Apply a thin film of oil with a rug all over, place a silica-gel bag in the case, store in heated, low humidify environment.
Of course! Silica! And how many of those have I thrown  out over the years. Thank you jdm! And after I apply a thin layer of oil, wipe off with clean rag I assume?
Just put few drops on a clean cloth or kitchen paper, rub all over parts to be protected.
I have what me chancel fitters were calling 'rusty hands' when I was an apprentice. I could leave handprints on anything steel. By the next day, there would be a rusty handprint where I had last touched something made of steel.
When I cleaned up on a lather after working on it, I would have to coat everything in oil as well as my hands. If I didn't, the next day I would be back there cleaning off handprints.
So it is not just air with me, but what I touch as well.
Thanks everyone for the replies and excellent tips! Off to raid my wife’s shoe boxes for silica packs and drain some Motul from her Pathfinder. What? You didn’t think I’d use the oil from my car did you?😝
I've been using jojoba oil for years in a hand tool woodworking paradigm (same problem, different scale). I made up a little sapele box with a reversible lid. One side of the lid is just french polished, the other side has a small piece of shearling leather glued to it (hide glue for what it's worth). Jojoba oil lives inside, and when I'm done with whatever tool, I drag it across the lightly oiled shearling, and then it goes to its home. The fatty acids that make up the triglyceride that is Jojoba oil are fairly long chain, and fairly saturated (as far as natural oils go), so it doesn't evaporate or go rancid very quickly.
An (old) toolmaker-turned-watchmaker friend told me they would put a piece of camphor in their toolboxes to prevent rust. He recommended it for staking tools in particular. Used to be moth balls were an easy source of a piece of camphor, but they are made from other stuff now.
If you live in a place with the right humidity conditions to promote rust almost no amount of oiling and silica gel will really work longterm. If you have climate controlled work area you can talk to an AC expert to find the right way to maintain your temperature to prevent condensation- not talking wet window level- microscopic condensation which is what causes the light rust on tools. When I was teaching in southern Ohio we were constantly battling rust on all the tools; the front office didn't want us messing with the AC settings so we never got to figure out the "sweet spot" and just lived with it. Very luckily the region I live in in Switzerland has the sort of magic humidity level and rust is only an issue when someone with rusty hands (as above) handles something.
I struggle with this issue a lot as well. Even simple household items rust very easily for me if they aren't good quality steel.
Colored silica gel are great. But they expire really quickly if the toolbox or storage container isn't airtight. In my case in just a matter of days, color changes from orange to dark green. If you buy in large batches and didn't store them properly, be prepared for a shock when the whole batch expires. Sometimes, they even arrive in the mail already expired, and if you got the non-colored version then there is no way for you to find out. Its a borderline scam.
Also, I don't recommend the oven/microwave method to recharge these, as you really don't know the quality control of these little balls. For all we know they could very well be tainted with uranium or cyanide. Or whatever.
So to really solve this problem, I use two things together:
1) An airtight drybox: I find the best are the ones camera enthusiasts use, they even come with hygrometers (shows humidity levels). I like the cheap Nakabayashi ones: https://www.nakabayashi-global.com/products-all/capaty-dry-box
2) "Branded" rechargeable silica gels: Eg. https://www.eva-dry.com/product/e-333-renewable-mini-dehumidifier-2-pack. Pop this in the box along with your tools, close the lid and watch the hygrometer go down. If it doesn't, then just recharge it.
  • 4 months later...
I agree with @Zero. Rust is a serious problem here in the tropics, where the temperature and relative humidity is really high (30 degrees celcius, 80% RH).
I store my more expensive tools in an air tight food container box (volume of over 10 liters), along with a CaCl2 dehumidifier. To be safe from leakage, the CaCl2 dehumidifier is placed in a separate plastic dish (IMPORTANT! I use two to be EXTRA safe), while the tools are kept in an uncovered plastic tray, both inside the sealed food container. I monitor the relative humidity inside with a blue tooth digital hygrometer.
The relative humidity inside the container is around 20%. However, you should replace the CaCl2 dehumidifier when you see some liquid (CaCl2 solution) at the bottom; in a sealed container it should last at least a few weeks, but depends how often you open it. I don’t recommend refilling the CaCl2 dehumidifiers, since leakage will destroy your tools.
The CaCl2 dehumidifiers are quite cheap, but you MUST remember to replace them, if not you will have very serious issues with corrosion from leakage of CaCl2 solution.
Edited by ifibrin
On 1/5/2022 at 6:12 PM, canthus said:
1 box of 7 lateral flow tests for covid-19 = 7 small silica gel sachets !!  Handy eh.
Great minds at work here. That's what I did with nine. Open a test throw the silica gel pack in the box with my staking set and jeweling tools.
I learned from @oldhippy that there is a thing called Vapor Corrosion Inhibitor (VCI) paper. Sometimes tools come wrapped with this brown paper that feels a bit damp. Well, it seems that a piece of this paper in the tool box will prevent rust of everything in it.
  • 1 year later...
Silica gel packs in bags of 100s are available on Amazon for very little cost, see example below. I use them with any watches I get, I put the watch in a small ziplock type bag 5cm x 5cm and throw in a gel pack to avoid any moisture damage until I get around to working on the watch. I also use lock and lock type containers for my infrequently used hand tools and spares etc, again throwing in a few gel packs in the bottom of the container for cheap insurance.
For removing rust from things like staking tools I find WD40 does a great job and is also a water dispersant (the WD in WD40) so protects against new rust at the same time.
Bags like these
And containers like these
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
