New Member
rubs3488
Hey
I am ruben
i am new to the watch making section
i just picked up my first watch to repair after seeing 50 video's on youtube i thought i would give it a go
and 30 minutes later. i am already stuck on the repair
if your wondering what kind of watch i am still wondering too so anything you have please let me know
i would love to learn more about it , what kind of movement it has i think a (tissot cal 27a?)
i would love to read your reactions
until next time
Welcome here. That is a quality mov.t and watch. As a complete beginner, with no experience and no tools it's practically certain that you can only do damage by messing with it. Save yourself the frustration, hindsight wisdom doesn't repair past mistakes. Leave it alone for the time being, and learn first on something of no or little value es explained in the topic below
13 minutes ago, rubs3488 said:
It is already broken
Sorry, you don't even know what is "broken". Even if if you knew, most likely you would not be able to repair it anyway with no tools, no parts, and no knowledge.
I believe that part of the "watch repair enthusiast" culture is to accept oneself limits and not inflict unnecessary damage, no matter how little one has paid a nice watch like this.
In all events, I wish you good luck and perhaps we will see where you get in one week, then one year from now.
15 hours ago, rubs3488 said:
but when do you think i will be ready for repairing this watch ?
After you will be able to take apart, clean, lubricate and put back together a cheap watch that is working, even if not perfectly. That without loosing or breaking anything.
For someone it takes one or two attempts, for others more. The topic about which watches one should start with is linked above, the below is about the few tools you need from the get go. The most important thing is the posture, you need good light and the work about at armpits height.
Below about the tools you need from the get go
Very true, I get a sore back when using a loupe for any length of time on a regular bench. For my back's sake I now use a microscope or kneel on the floor when using a loupe (knees on a kneeler).
PS I'm probably not as old as I sound!
I have an electric height adjustable table and I just couldn't do without it. When I need to use an eye loupe (using my jeweling tool or Jacot tool) I simple raise the table. It really facilitates the work and saves my back.
Sounds nice, but expensive?!
It's not a dedicated "Made by Bergeon table" (that would probably cost a fortune) but a simple office table that looks a bit like below, although electrified and wider. Got it for about $100 from an office that was replacing all their furniture and wanted to get rid of their old stuff as quickly a possible. They even threw in an advanced office chair in the deal. Everything in condition like new! 😁
Hi you have recieved some very sound advice based on knowledge and experiance and would do well to heed it.  As ldm said get a cheap working movement and practice, This not only hones the skill but as you are engaged in the task you will pick up some tools which are required for watch repair. Once you feel confident to tackle the Tissot go ahead, its a quality watch and requires respect.  To that end I have attached a bit of reading so as to familiarise youself whith the Tools and the working parts of a watch.  To do a quality job it takes time and the tools plus knowledge.  welcome to the world of Horology and good luck.
1867_Tissot 27B, 27b1,27b2,27b21 (1).pdf 1612608791_ToolsfortheHobbyist (2) (1).pdf TZIllustratedGlossary.pdf
That sounds ideal. I have been playing around by getting low chairs too but using my microscope as much as possible saves some back ache. I might get one of these next year to raise the height of my table:
https://www.cousinsuk.com/product/watchmakers-portable-bench-horotec-swiss?code=B45571
My spending has already got out of hand!!
@Ruben sorry to hijack the thread a little... welcome to the forum, I'm fairly new myself but can tell that the Tissot is a very nice movement which you wouldn't want to ruin. If you're going to service it, just take your time and feel free to post any questions, you'll get plenty of help.
    • With something like this a gasket seal for instance if i cant find the relevant information i would use instinct to decide what fits and works best. You have the original gasket ( well maybe its original or hopefully it is )so its fairly easy to determine what material to use. Shape , for that i would look at the gasket seatings, are there grooves or recesses in either the case back or case or both, what shape are the grooves, flat or round etc, how does the gasket sit and behave in those seatings. Next thickness,that is going to be a bit of a guess, especially if the gasket is a soft one that has been heavily compressed over time. This is where a selection is going to come in handy, personally i would be choosing one that is giving me the feel of compression as its coming into contact with both of the mating surfaces. But not so much that the gasket is going to squash out and become distorted, again this is guesswork and feel is required with the allowance of compression over time, something you may want to check after six months. This part is a little moot as without a pressure test, good water resistance is not assured so the watch needs to treated as such and not as if it were a new diving watch ( not that i would treat any new diving watch as if were ). What you want to expect from your efforts is a little accidental rain catch, if you want more water resistance guarantee then a professional gasket replacement and pressure test is what you should be seeking which will be more than the value of this watch. Coincidentally i have the same watch, been searching for a stem for it for a while now.
    • It might not be a hook it might be something like this. But still the mainspring is catching on something on the slip ring because it doesn't have its own outer slipping part like the modern ones. The image below came from some vintage Omega thing I'll have to see if I can find where that has gone to.documentation A different book has this
    • I did not see a hook on the slip ring. I will check again tomorrow.
    • I think I'm having a confusion here? You would apply the breaking grease to the inside of the barrel then the slip ring would go inside. Then the mainspring goes in and it catches on the hook on the slip ring.
    • Thank you for the once again very thorough and informative reply. I'm sure at this point it's academic, but I'm always curious to know best practices. This then implies that If I'm planning to reuse the old mainspring (which I am), I should also reinstall the slip ring. I will do that and apply braking grease to the inside of the slip ring as if it were the barrel. This makes the most sense to me. Also, that bit about the center cannon pinion is very helpful. That wasn't in the tech sheet I have (attached) dated 1970. Omega 1001(1).pdf
