Bezel won't snap on
arron
Good evening,
I have two Ingraham Biltmore dollar pocket watches that i took the bezels off of but for the life of me I cannot get them to snap back on.  I tried to hook one side of the bezel to the case and then put finger pressure on the other side but the hooked side always comes off.  I have tried applying some pressure using a crystal press but that didn't help.  Does anyone know the trick to getting the bezel back on (btw the back of the case snaps back on fairly easily).  Thank you.  Arron.
Are you trying the correct bezel for the correct case? Even pressure is the answer, look closely at the bezel and case to see if there is any mark that gives you a clue to the correct place it fits. Is the bezel bent this will prevent it from fitting correctly.
Hi OH.  I am trying the correct bezel.  I threw the other bezel in the picture because it's having the same problem on a similar model PW.  The bezels are both unremarkable so they are not giving me any clues.  I was thinking about heating up the parts with some warm water to see if that would help anything.  Then maybe trying to grease one size of the bezel to reduce friction.  Hopefully I'll get'er figured out.  Have a nice day.  Arron.
That won't do anything, a much higher temperature would be needed, but that is guaranteed to ruin the part. To press in a tight fit on soft metal one needs precisely shaped dies which will not mar the part, like nylon or delrin, and perfect alignment under a screw type press.
With John's advice I went back to the press and pressed with more confidence this time and the bezel made a cracking noise (not sure if that is good) and the bezel went on.  I don't see any actual cracks anywhere so hopefully it's good.  Thanks John and everyone who chimed in.  I really appreciate it.
Just be careful if you have a solid gold case. I made the mistake of trying to press a bezel on to a gold Longines case, pushed a bit too hard, and distorted it badly.
    • I'll have a look for it, but don't hold your breathe. Failing that I'll make another video when another bezel needs to be removed.
    • The UK lots can be a 404 hit or miss, 6 - 10 watches can come in anywhere from 20 - 50 quid. I once had a 404 division of 8 watches for a fraction over 30 quid, one of them was a Smiths Astral model National 17 an absolute certainty for winner contender. The crystal was scrached up to the point of being very difficult to see the brand, something triggered a gut feeling in me and it paid off.
    • I just picked up this Mondaine quartz watch on tradera.com for £11. It's a non-runner so I will replace the Ronda movement (£10.95 at Cousins), polish the case, replace the case-back gasket, and replace the mineral crystal. Now, the problem is finding a suitable crystal. The original crystal is slightly domed (2.4mm thick dome), measures 36.4mm in diameter, and is 1.3mm thick at the edge. The closest I can get on CousinsUK is 36.5mm in diameter, 3.1mm thick dome, and 1.5mm thick at the edge. I think the replacement crystal would look OK, but the problem is finding a suitable glass gasket. The case diameter for the glass gasket is 36.9mm and the closest glass gasket I can find on CousinsUK is either 36.8x36.0mm or 37.0x36.2mm. I guess one of those glass gaskets could work but as you can see there's no way the 36.5mm domed crystal would fit the inner diameters of those glass gaskets. I guess I will have to give up on a domed crystal, no? So, the backup plan is to use a (1.5mm) thick flat mineral crystal as the diameters come in increments of 0.1mm. But, what glass gasket would be the better option? The one with an outer diameter of 36.8 (0.1mm too small) or the one with an outer diameter of 37.0mm (0.1mm too large). Again the case diameter for the glass gasket is 36.9mm. I believe I read or heard that the crystal diameter should be 0.1mm wider than the inner diameter of the glass gasket. Is that correct? I'm sorry for all the numbers. I've tried to make it as clear as I could. So, I'd appreciate your thoughts on this. BTW, measuring and sourcing crystals and gaskets is extremely time-consuming! 😓
    • Lots to choose from... Just sayin'.
