I have this cross slide which I refurbished many months ago, but never really used it.
Now I cannot figure out how to use it.  How to get the graver at the right position vertically?  Some fundamental piece of knowledge is missing in my brain.  As you can see, the graver is too high.  Maybe a different cut on the graver would solve this.  Dunno
Ideas?
as a variety of ways that this could work but usually the simplest is your missing something. I'm attaching an image there is supposed to be a piece that goes on the bottom that's curved so would allow you to tip the graver and get it in position.
although your bottom piece looks to tall like maybe it's not supposed to be there?
Ideas?
What make is the lathe. On my Star lathe this set up would not work Just too high. Also I have to use small cutters that I made out of HSS steel 3/16 x 4 to fit so I use very rarely unless I need an absolute dead parallel cut perhaps you need smaller cutters too. See pic of the Star cross slide + a cutter I made.
EF0A59D0-6942-423D-819A-1548EFFBC645.thumb.jpeg.2bd41ecd2a8331e881bb86830390a710.jpegB2326B12-2859-477E-96CF-9BF18E0B5B67.thumb.jpeg.fe6b15b28b08681671892e8bfb9dd125.jpeg1294B314-630E-4A6F-A35C-349419138992.thumb.jpeg.e20df1045036eff2481d6efee227fb08.jpeg
52 minutes ago, oldhippy said:
Are you sure it's the right one for that lathe.
that is an unfortunate problem with watchmaker's lathe is of acquiring bits and pieces over time. there should be a name on the  lathe somewhere and another name or possibly the same name on the cross  Slide.
Then I'm wondering if the tool post holder is the right one for  this  lathe?
That's a rocker tool post. But on the OP's tool post the knurled ring should be the height adjustment, it should be threaded somewhere.
Yes, it is threaded and cranked all the way down.
So when you unscrew it that will raise the tool to the correct vertical position. You should always try to align the cutting tip of the tool to the spindle axis, there are various methods to do that, all explained in the abundance of books and videos on the subject.
Yes, I understand. But I cannot get it low enough to align with the spindle axis. John suggested a holder that has a rocker. I think that would work if I had one,
Which cutter size are you using, and how much down have you ground it?
A common HSS tool size is 3mm square, or 1/8". Even 2mm square is available. These are all good for watchmaking work. You could also check if it's feasible to cut off the last mm from the part that sits on the cross-slide.
Quote
These normally are not recommended anymore but surely you can look into that, but be aware that as you point the tool down (or up), you will need to grind the rake accordingly, in practice that is a groove when seen by the side, which is slightly more difficult.
However for work done with a toolpost (which is not dominant in watchmaking), the demanding craftsman would upgrade to a Quick Change Tool Post. Examples of that are the Multifix AAA, or the Aloris MA. If after checking these out you will think they're expensive, then I will point you to the Swiss made ones.
All of these types of lathes are 50mm height from the center of spindle to the bed- with the exception of Marshall/Peerless, who went with 2" height; but in this case that would be a help as that gives you an extra 0.8mm of height (not kidding, that can help!). But from memory you do have an actual Marshall slide, so either there is more adjustment in the post but something is sticking, or as above, you need a different one.
Dig though your stuff and see if there's another toolpost somewhere.
I am not familiar with these lathes but in pics I see 3 slides, with the compound in the middle. The slides appear to have some thickness and a space in between, how can all that fit into 50.8mm and still have some distance from the top slide to the spindle? The adjusting knob is maybe just 0.8mm high, do one has to run it clockwise and cut with the bottom of the tool ?!?
I presume the tool needs to be lower obviously higher is done with shims. If it requires lowering a fraction could you just reduce some of its adjuster height.
No shims needed, the knurled knob you see under the tool is to adjust its height.
Just now, nickelsilver said:
the bottom of the bottom slide should be smack on the bed, what's that gap?
That is the space I was referring to above.
Either that cross table is not the correct to the lathe or the post is the wrong type. The curled nob seems to be at the bottom locking the post in the upper cross-slide.
But looking at the picture you posted there is a possibility you could use that setup anyway.
You could grid a HSS tool so it is in the center of the lathe axis. If it is too high up from the center line it will not cut correctly and get dull faster and if it is to low, under the center line it will risk to catch and get stuck in the material you are cutting instead. The softer the material the greater this risk are.
Just grinding the tool needs a chapter of explaining itself.
How do you have it mounted to the bed? the bottom of the bottom slide should be smack on the bed, what's that gap?
Dammit!!!!!!
This is the only lathe with that plate for mounting the rest.
I feel so dumb.
Tanks to everyone for working my issue so hard!!!!!!
    • What size is the movement and have you done the usual search with bestfit. To me it looks like something in the 10 series. The other option would be to measure the staff and try and trace it from their, or at least find an equivalent.
    • 1mm copper wire can be tapered to fit. Softer than brass but it does work.
    • You would think so.....but maybe not. I did just that with a 50's Oris tank. 5 years ago.....stripped and polished...it hasn't tarnished and looks exactly as it did..I wear it often. Looks like brushed gold plate.
    • This poor watch now has a new escape wheel jewel. I got a jewel assortment and found one that fitted snugly in the setting, and whose hole was a neat fit on the escape wheel pivot, glued it to the flattened end of a 1mm drill bit and turned it on some brass with diamond lapping paste to give it a taper on one side. I used a sewing needle to gently close the setting over the jewel. It doesn't look too bad in the pic, but actually about the bottom third of the setting has nothing left holding the jewel down and I'm not sure whether it will hold. I'll have to see when I reassemble it. Before I reassemble, I thought I'd better have a look at the balance and check its poise. I put it on a pair of tweezers and found it did indeed want to always stop with the same point uppermost, swinging to and fro around that point. While I was thinking about timing washers and that I don't have the right tool to remove a timing screw, I noticed that one of the pivots didn't look straight. A closer look was called for: The right hand (upper) pivot is definitely bent. So, should I try to straighten it? It is likely to break, I suspect. Am I going to be able to buy a replacement balance staff for a watch more than 100 years old with no movement number? Seems unlikely. I have no lathe so I'm not in a position to make one myself. What are my options?
    • Here’s is an update on the watch. I haven’t worked on the watch since, but I seems like the watch is now running perfect if he don’t wind it fully up. If he just wind it almost fully up, it doesn’t seem to stop.. and it stops after some time if he wind it fully up.
