New User saying hello
RayTee
Hi all, just to introduce myself before asking what will no doubt be a lot of silly questions 🙁
Recently retired and starting out in the world of watch repair. I find it an absolutely fascinating art and now wish I had started years ago.
like many others I have watched countless youtube videos but still find it all a bit daunting.
Guess I’ll have to take baby steps for now and take my time 🙂
Seems like a nice friendly forum and a lot of very knowledgeable people on here.
thanks
Ray T
Hi Ray. Welcome to WRT forum .
Start with two cheap scrap pocket watches, carefully selected you should end up with a working one out of the two and gain confidence too.
As our good moderator oldhippy says ," no question is silly".
Good luck
Thank you very much guys. That’s sound advice and quite a comprehensive list of tools and a very in-depth guide.
I love the way you explain the reason for certain choices of tools, and share your own experiences as to why you made those decisions.
I do have a few old watches to start “ playing” around with but no pocket ones . . I do however see the logic in starting with the larger one.
Thanks again for the help and guidance gents
Ray T
Thank you for your introduction and welcome to this friendly forum.
Everyone has to start somewhere, we don't treat any questions as silly. I little tip when asking if you can provide a good clean photo it helps,  it can help others that might not be so knowledgeable as some, it also helps more to take part.
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
