Having systemic problems with low amplitude on every watch I practice on
By eccentric59 · Posted
You mean all that stuff about aliens and black helicopters isn't true? -
Thanks yes it’s nice to make tools and equipment if we can , I needed a fixed steady for my Pultra I had one for a Pultra with 70mm centre and I was going to cut it down to be able to use it on my P type ( 50mm centre) but it seemed a shame to butcher such a rare item so made one. Dell
Go and drill with 0.4, then finally turn the piece to size untill it fits the hole. Don't worry, if something happens, You can turn new arbor. -
By Terrinecold · Posted
Well I can't always report good progress. I just spent an hour trying to set the barrel bridge. That is one bridge which goes over: The barrel The driving gear for ratchet wheel Reduction wheel sweep second pinion (which is on a spring) Third wheel and pinion fourth wheel and pinion escape wheel I still haven't managed to do it. In particular, most wheels I can jiggle a bit to make their pinion go into the jewels but the sweep second pinion and the fourth wheel are not accessible once the bridge is in place and everything else is good. Does anybody have suggestion? I have already reassembled a Miyota clone but it was also a bit bigger than this movement which is a pretty small one -
By ScrewDropper · Posted
Rotary usually have either ETA or AS movements in them. I work on them a lot. Vintage Rotary are under appreciated watches, usually with a nice movement. You can pick them up dirt cheap, spares are easy to find and they're usually really nice to work on.
