Can you spot why this is a marriage
oldhippy
At they are selling it as sold as seen and not a genuine article. As Bod said, it would be good to see inside but the fact nothing seems to fit clearly shows it's not right. The dial is quite impressive - I didn't know you could do that!
I'm not even sure if the chapter ring goes with that dial, look at the nasty way it has been riveted on with steel rivets at 12,3,6, and 9. I have trouble believing that the original maker would fit it so clumsily.
It's hard to tell from the photo but the dial also looks like it has gaps below and to the left so it does not fit the hood.
I'm also guessing those hinges are not original either.
The case and style of the clock looks ok its made of oak, the dial also looks original apart from the re work and fitted blanks (badly) which would mean a movement change. Normal Wm Hargreaves 1741 to 1813.  clocks go for around £800 to £1000 plus as this is offered at £250  and the fact there are no movement pictures  bascially its a Bitsa (marriage) Settle is in North Yorkshire near Skipton, My home county.
Many longcase clocks had the bottom either cut off or added due to the fact most of them stood on stone floors and were subject to a great deal of damp as the floors were scrubbed and swilled off with water with little regard to the clocks that stood on them. only on the big houses did they stand on oak or pine floors and did not suffer as much.
The taper pin on the center arbor is the only way I know there isn't a quartz movement hiding in there.  Outside of that, not specializing in this kind of clock, seeing mismatching with appearance and fit and finish would make me wary enough to stay clear of it, unless I became determined to restore it.
A waste of money restoring this. It would be throwing good after bad.
    • Update, I discovered that I could change the mainspring by removing the arbor and sliding it out from between the front and back plates. So I put a new mainspring in. This it what I  get over a 7 day period After winding                                          amplitude is 1 1/2 turns plus a few degrees.        ie just over 1 1/2 turns. 1 day after winding     gained 1 sec      no amplitude check. 2 days after winding   gained 1 sec      amplitude 1 1/2 turns        i.e. it lost the few extra degrees 3 days afer winding    gained 3 sec     no amplitude check 4 days after winding   gained 5 sec     amplitude 1 1/2 turns        i.e. unchanged 5 days after winding   gained 7 sec     no amplitude check 6 days after winding   gained 16sec    amplitude just over 1 1/4 turns 7 days after winding   gained 24sec   amplitude 1 1/4 turns. From  Based on video inspection, I am getting full pallet lock. So, my data seems to be at odds with the statement "swing of a balance wheel has nothing to do with the rate". However, I have noticed the banking posts are not controlling the lever position on the right side.  I may have some work to do here.
    • I can't tell whether or not some stem is stuck in the crown, I  think so though.  If the crown is stainless steel you could try alum to disolve the stem of try drilling it out. If all else fails, buy a new crown.
    • Does anyone use the x5 eyepieces,  when i use them on my different amscope , the magnification changes to x5 but the field of view remains exactly the same as the x10, so nothing gained. The optical lenses can't be swapped out or at least they are not available as far as i know.
    • I think maybe we're all a bit dim @ManSkirtBrew 🤣 99% of the time I'm working with the 0.5X Barlow, so mags from 3.5X to 22.5X. When I need a close up of a pivot or jewel, I take the Barlow out, and even put in the 2X Barlow, but it's a nuisance. So like you, I had that D'oh moment, why don't I just use 20X eyepieces (WF20X/10). They take seconds to change, and you keep the working distance. The only downsides are lower field of view, and less brightness.
    • At the lowest magnification, I can just get all of a normal wristwatch size movement in field. For some things it's too much magnification, but the nice thing about the eyepieces is they only take seconds to swap in and out. I'm genuinely surprised I've never read about anyone else doing it, to be honest.
