Can you spot why this is a marriage
oldhippy
At they are selling it as sold as seen and not a genuine article. As Bod said, it would be good to see inside but the fact nothing seems to fit clearly shows it's not right. The dial is quite impressive - I didn't know you could do that!
I'm not even sure if the chapter ring goes with that dial, look at the nasty way it has been riveted on with steel rivets at 12,3,6, and 9. I have trouble believing that the original maker would fit it so clumsily.
It's hard to tell from the photo but the dial also looks like it has gaps below and to the left so it does not fit the hood.
I'm also guessing those hinges are not original either.
The case and style of the clock looks ok its made of oak, the dial also looks original apart from the re work and fitted blanks (badly) which would mean a movement change. Normal Wm Hargreaves 1741 to 1813.  clocks go for around £800 to £1000 plus as this is offered at £250  and the fact there are no movement pictures  bascially its a Bitsa (marriage) Settle is in North Yorkshire near Skipton, My home county.
Many longcase clocks had the bottom either cut off or added due to the fact most of them stood on stone floors and were subject to a great deal of damp as the floors were scrubbed and swilled off with water with little regard to the clocks that stood on them. only on the big houses did they stand on oak or pine floors and did not suffer as much.
The taper pin on the center arbor is the only way I know there isn't a quartz movement hiding in there.  Outside of that, not specializing in this kind of clock, seeing mismatching with appearance and fit and finish would make me wary enough to stay clear of it, unless I became determined to restore it.
A waste of money restoring this. It would be throwing good after bad.
    • Please OH, we should all be proud of our collections what ever they are. If we can't show them off here then we can't show them anywhere. Our favourite gives us a story to tell of why we love it, that story also tells others something about ourselves. These are some of the things that make our forum and our community so amazing .
    • I can take pictures when I am home of what it looks like.  They will be phone picture as I don't have a camera in my microscope yet but I should be able to take a few views to give a good idea of the damage.
    • One I have and it's a French Strike on a bell with Garnish worth around £1,000. I'll take a photo of it tomorrow so you can see it.
    • When you are having fun restoring false economy exits via a window. Your time and money dont always matter Col , what does matter is that you breathed new life into something that was dead and destined for a scrap heap. That has to feel good doesn't it ? Some of my favourite watches to wear are my first attempts at repair. With a face that only its repairer can love , Rolexes pah !!! give me a Smiths pin pallet any day of the week.
    • Hi, I'm Ciaran from Manchester. I've have been teaching myself watch repair since January. Funnily enough it started with me replacing straps when I was laid up with a knee injury. It grew from there after coming across the YouTube channels Watch Repair Tutorials, Chronoglide, and that of this forum's owner.  My first proper repair job was disassembling and reassembling an ETA 955.112 (with the help of a video by Mark and a walkthrough from this forum.  Since then I've completed a few services of ST36s, as well as a truly battered AS 340 which had more things wrong with it than it did right.  I'm currently working on a pocket watch from WW2 - which I'll be attempting to fit a new balance staff to. As well as a Tissot 781-1.  For those of you on Instagram I'm there also: https://www.instagram.com/ciaranwatchrepair?igsh=MWZ3bHNmdDUzdGhqbQ== Happy to have found another place to talk watch repair
