Hello to all,
My name is Ash (from NZ). Im a watch enthusiast and trying to learn more about Horology.
I have been picking odd watch repair jobs here and there and self-learning.
Firstly, thanks a lot to Mark Lovick for uploading fantastic videos on youtube that are so simple to follow. Keep up the great work :)
Question - is there a way to diagnose quartz watch circuit using those test probes (that have an LED inbuilt) or perhaps using a multi-meter? For some watch movements such as Myota 2035, it makes sense to replace the whole movement. In other cases, it make sense to repair it (if possible).
Is there a way to narrow down the faults in quartz watch? For instance, if a watch is gaining/loosing time, it could be the quartz crystal out of freq etc. how can it be scanned appropriately?
Im not sure if its even possible or not. Hopefully I could get some help here.
Thanks a lot in advance
Ash
A friend of mine who's an amateur, but very competent, repairer, has a machine on which he places the watch - minus battery. When he presses a button, the magnetic mechanism inside the machine kicks in and turns the watch movement and hands at high speed. If the hands and movement don't whizz round, he considers the quartz movement to be probably beyond repair - broken circuit board, faulty coil, etc. If the movement does run on the machine, then it may well be repairable.
Apologies if you know this already - I speak as an observer - and apologies for not knowing what the machine's called!
Oh - and a warm welcome to the forum!
Edited by WillFly
Hello Ash,
                 Welcome to the forum,  which seems to be growing very rapidly, by the way.  I'm afraid I do not know the answer to your question, but I think a good place to start would be to find out the name of the quartz tester Will mentions above.  There are members at all skill levels on the forum and no doubt someone will have more advice for you.
I thought that if it's any other thing than the coil it's u/s. But isn't there something about a coil being separate from the board that changes the games a little. Like the boy's have said the name of that device would be handy and knowledge from the man would be good. There are many levels of skill on the forum so good luck with it and Wecome to the forum btw. ;)
Yes you will need a multimeter and access to the data-sheet for the movement will be a help.
Israel's tool looks really good, but I have not got one.
Other meter's made by Witschi are extremely expensive but are industry standard, they rarely come up on eBay but you could get a bargain from time to time.
hi WillFly,
thanks a lot for your comment. that machine is called 'demagnetizer'. if the movement runs freely on magnetizer, that generally means gear train is fine. it also means the fault lies either in coil or circuit. i do have one of those already. its a cheap chinese one but does the trick :)
I was more keen on learning how to fix the circuit, if possible. I have succesfully fixed few coils. they are not too bad. Le arsi has got a good video on it
Cheers for your help :)
Ash
thanks a lot to Autowind, Craig, SeikoWatch & Mark Lovick for their comments.
i have been thinking of building something similar to what LeArsi shows on youtube. looks like a good nifty project :)
Most of all, really appreciate the wearm welcome i have received on this forum so far. Glad to be a part of it.
i have got one more queestion re Watch crystal glass. I will make a seperate thread for it.
Regards
Ash NZ
Not sure I recommend a de-magnetiser. I know it pushes the wheels around but my fear is it would potentially affect the stepping motor. I have no evidence of this - it's just that I can be a cautious bugger :)
The Etic Polytest and Omnitest both have that function plus they generate a signal to indicate if power is going through the circuit.
They are great machines, and come in very handy - I have had them for years.
Sadly they are no longer being manufactured but I do understand there are some alternatives out there.
I have fixed a few coils in the past but circuits are not my thing, if I feel one is damaged I would rather replace it if I can ;)
  • 5 months later...
Hi Ash welcome to the forum. I'm curious too about your question so please keep us posted of any progress...and if you build a tester I might be interested! Quartz is not my line of expertise ( and barely the others either, I'm a beginner).
  • 4 months later...
Dear fellow members,
I currently own the pictured tester, nevertheless, I'd like to do a more in depth testing on individual circuits in the watch, like component resistance/impedance, continuity, etc. This one is supposed to do some but is not a full meter.
Do you have a suggestion of what would be a good amp/ohmmeter and/or full tester for in depth work on digital watches? Thank you in advance,
Bob
In my humble opinion most quartz movements are not worth the time & effort to repair. If it don,t run with a new battery just replace the movement.
Edited by clockboy
Thank you clockboy, I do too, but regretfully this movement I will be tackling is US$100! I'm talking about the ETA 251.272 and the next in line in my workbench is not much better, ETA 251.471, same price! If all is well, it will be very rewarding to have them going again without a transplant!
I recently serviced an Omega DeVille quartz watch...
Held my nose while I opened the case, but lo and behold the movement was actually a lovely lovely thing. Thirteen jewels and the bare minimum of plastic.... i'll dig out a pic...
Actually Dave the Watch Guy has a teardown of exactly the same watch:
http://watchguy.co.uk/service-omega-ladies-deville-calibre-1471-quartz/
Edited by mwilkes
When replacing a battery in a Quartz Movement I check the consumption and rate.  This is a good indication of the health of the movement.
Consumptions:
Basic 2 Hand >900nA
Basic 3 Hand >1.5uA
3 Hand with Complication >2.0uA
Chronograph >2.8uA
Rate should be very low ... like +0.15 sec/day
If I get high consumption readings, the movement needs a strip and clean.
If I get no readings, I check the coil for damage or corrosion ... if it's good, then I isolate and check the Quartz is oscillating, and then isolate and check the IC.  Either of these two are the issue, then you need to replace the circuit ... because most manufactures won't sell you a crystal, or coil these days, which stinks!!
The machine I use is the Witschi Q1.
Thank you Lawson,
Very clear instructions. Do you have a suggestion for a good volt-amp meter appropriate for this? I don't think I'll get into a witschi right now although I'm already drooling at the sight of it. :)
Cheers,
Bob
Consumptions:
Basic 2 Hand >900nA
Basic 3 Hand >1.5uA
Chronograph >2.8uA
I believe you made mistake,there are maximum values for every movement provided in the technical document of the manufacturer of the movement, as it is written in your post now it seems that there are minimum values, whuch is not correct.
Besides the values of power consupmtion there are two values whiich should be checked also:
Lowest working limit(voltage on which movement stops working)
Rate i dont need to explain this
br
emso
p.s sent from my sh**y phone, so sorry for typing mistakes
  On 12/5/2014 at 8:17 PM, emso said:
ROFL! :D  Sorry I always get those stupid symbols back-the-front ... They are max values peeps, and I'm an idiot :p
Oh yes, I forgot to mention the lowest working limit.
To explain, this is when you connect probes to the battery terminals, sent a set voltage to the watch, and note if it's still running.  Starting at 1.5V and dropping down from there (you can set these voltages on the tester).  A good movement should still be ticking at 1.3V, and at this point, or below, should be going into it's "Low Battery Warning" mode of ticking off 2 seconds at a time.  Then lower the voltage more until the watch stops, and note down that voltage.
  On 12/5/2014 at 6:01 PM, bobm12 said:
Thank you Lawson,
Cheers,
Bob
Sorry mate, I don't know of one.  I work on Quartz all day at work, so I only do mechanicals at home.  And the cost of these testers is crazy expensive!
I have been told, and seen, that cheaper one have trouble testing some of the Japanese Movements, so if you are serious about buying a tester make sure you do your homework that it covers all the bases.
  • 11 months later...
  • Similar Content
    • Sorry @nickelsilver, I'm just seeing this now.  It is a standard metric screw plate. I followed the suggestion of doing the thread cutting in a pin vise.  It took me forever because the piece is so delicate that I cut and cleared chips very frequently.  But eventually I did get it.  Not pretty, but I got it; the first thing I ever successfully made on the lathe. I cut the screw slot with a jewelers saw.  How can I ensure that the slot is centered on the screw head?
    • Hello, My name is David and I’m a vintage watch collector/ wanna be hobbyist watchmaker from France. I really want to progress into my watch repairing hobby. For now, I’m only having fun servicing my own watches and spare movements, simple small 3 hands from the 50s (Omega, eterna…) Learning step by step or at least trying to 🙂
    • More setbacks and successes...  After letting the watch run in (but before I fixed the BE) a chunk of the radium lume fell off one of the hands and pulverized leaving radioactive dust all over the dial 😞 ☢️ ☠️ So before I could continue further I decided I would remove the radium lume.  I have removed radium lume from hands before where it was already starting to flake away but this time I had to work out what I was going to do with debris on the dial.  I decided that getting everything under water and removing all the lume was probably the best way to go. So here is what I did... I put an essence jar I use for cleaning parts and filled it with water and put it into a big ziplock bag along with the tools I would need - a sharpened piece of pegwood and  a 0.80mm screwdriver  -  I put on a pair of nitrile gloves and a covid style mask and then opened the back of the watch. Now with the back off the watch I could do the rest inside the bag.  I removed the watch from the case and removed the hands from the dial (through the bag) and then undid the dial screws and removed the dial from the movement.  I then put the hands and the dial and the watch case into the water and removed the movement from the bag.  Carefully and slowly with one hand in the bag and one hand trying to poke and hold stuff through the bag I gently rubbed away the lume from the dial and hands with the pegwood. I then took the parts out of the water and removed the jar from the bag (leaving the parts still in the bag) - with the majority of the dangerous stuff now in the water I disposed of this (down the toilet) and gave the jar a good rinse in running water before refilling it and returning it to the bag where I gave all the parts another rinse in the new water.  I then took the parts and put the geiger counter over the top of them and looked at them carefully under UV light to see if there were any flakes still hanging on. I dried everything with some kitchen towel. Once I was finished will all that I remved the parts from then removed the gloves and put them in the bag with the paper towels and the pegwood and thew the bag in the household waste. Finally I gave the dial, hands and case another rinse in the sink under running water.  I didn't bother following up with a rinse in distilled water water because the water here is pretty clear of limescale etc and I find it doesn't mark! So here are the results of my weekends work! Timegrapher dial down (dial up is almost the same) The fixed shock setting New crystal - and lume removed from dial and hands
    • Hi and welcome! I'm new here too—greetings from Leicester, UK.
