Hello from Australia
There's not enough information on your original post to determine the movement and what the correct spring size should be. If you're confident with your measurements then the GR6573 looks correct apart from the end termination, again, without more information I can't assist further.
Could you explain it to me in a easier way what did you mean shimming cock word do what you mean setting house is that the cap jewel
Thank you. Please see earlier post here about same watch
Hello Murks. Always consider if shimming the cock would do. Check if pivot shoulder rubs on setting's housing. roller table and balance rim to be checked as well. Regs
