Hi! Ludo here from NL
hi all! After watching +50 hours of YouTube restorations and practical how-to's, I've took the plunge into watchmaking myself, starting with a non-working Lanco 1233 automatic and a basic set of tools. Can't tell you how happy this hobby makes me! Little about myself, 34 year old living in The Netherlands (Amstelveen). Current owner of a 1973 Rolex Datejust and a 1971 Omega Genève (did NOT restore these myself ;)). Currently working on Lanco 1233 (17 jewels) and Oris Super 482kif (17 jewels). Expect some questions from me in the foreseeable future!
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
