Mainspring winder
Willow
Hi, i am trying to buy a winder that does barrel and open springs why is it so hard to buy one in the UK ,cousins is having trouble getting hold of Ollie Baker Style winder and to get them from US are expensive i have tried searching the web with no luck , can anyone recommend a company in UK that does them.
Build your own as stated above, The Ollie Baker supply issues are a bit of a joke they have been continuously out of stock at Cousins for years they occasionally become available but if you dont spot them on the day they go on the site you wont get one they go that quick.
The Ollie Baker is a pain to use anyway with small barrels and very large barrels anything in between is o.k very large Fusee barrels are a real struggle and a feat of strength because you have to grip the barrel as you tighten the spring up to get the sleeve into the barrel and they are even worse when trying to get the spring back in the barrel , I have a Bergeon winder that I use for putting fusee springs back in.
Edited by wls1971
wls1971 you surprised me with Ollie Baker i thought they were supposed to be one off the easiest and safest to use, thanks for that
14 minutes ago, watchweasol said:
Hi Willow   have a look under "identifying clock" by Mechanicmike the whole plans are there just had a look,  its in six parts giving measurements etc... It will be in the clock corner.
yes i will a search for that thanks for trying anyway
They are good mainspring winders but there are some glaring faults in the design, you have to grip the barrel in your hand to tighten it, they supply a jubilee clip that you are supposed to put round the barrel and tighten there is a bar on the winder that you wedge onto the jubilee clip to hold the barrel as shown below:
This is a very bad idea you are putting strain on the clip in the very place it is not designed to be strained the strength in a large spring would cause the clip to fail. I have spent my working life in the chemical industry and Jubilee clips used to be a fairly industry wide way of connecting hoses we stopped using them in the early 90's because of high failure rates.
The hooks on the Ollie Baker for holding the hole end of the spring as supplied are too straight you have to be very careful they don't slip out the hole when tightening the spring up to remove a spring from the sleeves.
Some times the opening for the barrel is on the opposite side of the barrel to the one shown in the picture that leaves very limited room to get the sleeve in the barrel.
I would just say they are good but not perfect.
Can i ask your opinion on Bergeon 4126 are they any good they are a lot cheaper, i would prefer to buy one then make one put if thats the only solution i will have to go down that route
Hi Willow As wls1971 said holding the barrel in your hand using a jubilee clip on a stop is a dangerous. The Ollie Baker pattern is the same but no stop just your hand. The DIY uses a clamp to hold the barrel so no hands, and the attachments for loop ends and hooks are made to suit your own tastes. Of course there is also the webster mainspring winder see attached, but its get from America.
Hiya Willow
I'm currently(I should say we!)working on an anniversary clock and came up against the mainspring problem. Unless you're dismantling and repairing clocks exclusively, the winders are very very expensive and hard to find, but they are out there. The 'Bay has a few, and I actually found a Keystone, and a Bergeon out there when I looked a few minutes ago. But soooo expensive. So, when I get the time I'm going to build my own, as I don't see myself doing just clocks. They are fun tho.
IMHO.
good luck!
BTW Bergeon 4126 apparently would work. Hippie uses one.
Hiya Willow
IMHO.
good luck!
Hiya Willow
IMHO.
good luck!
MachanicMike yes they are expensive i think I will give a try and build one, the anniversary clock I am working on has been put to one side while i work on a case of a 1950s time only clock that's seen better days good luck to you whatever you do
In the 'Bay today
19 hours ago, watchweasol said:
Hi Mike That was designed for the 400day/anniversary clocks but with the right retainers will remove other clock springs, The DIY versions of which I have built two and moose has built one do the job admirably, Fusee clock springs need a beefier version
My bad. I thought he was looking for that specifically. I remembered you built some that were well done.
Hi I forgot to mention there is a full set of plans on the site (supplied by Joe Collins) for you to make your own should you choose to do so.   If you cant find them I have then stored on the laptop.
Yup. I posted them and have them saved on my laptop as I plan to build one myself.
Another shiny object!  LOL.  I could not resist pondering a 3D printed solution for some of the parts.  I don't have the plans...just taking a SWAG at what I see on the youtube videos.  Here is one of the slides.  The mate for the slide is a trivial design and print as well.  I just quickly laid out this piece.
1 minute ago, watchweasol said:
Hi  There is no reason why some of the parts cannot be done on a 3Dprinter all you have to remember is the strength the spring has when coiled.
True.  I print exclusively with PLA.  It is extremely strong.  ABS is stronger, I think.  I can print ABS, but puts of vapors that are not office friendly.
Are the plans posted on this forum?
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 at 20° C) than 9504 (305 at 20°). The viscosity of Molykote DX is 285-315 at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease.
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
