New Find!
kendallronin
20 minutes ago, kendallronin said:
Ah , thx I'll just use it as an everyday time keeper. Its a strong runner. I thought I had a good one. Thank you very much.
 Let us see the movement, since Dr ranfft doesn't show it.
Cased outside Japan means its not high end or grade. Perhaps.
Nide watch, I like it.
The movement should be a 66, probably 66B, a nice small movement, hand winding, 17 jewels, 18.000 bph, diashock and diafix on the escapement wheel. I have several Seikos 66B and I've really enjoyed servicing them. They keep very good time, with just a few seconds deviation a day.
2 hours ago, Nucejoe said:
...but mine came in ladies watch.
Yes, it's small so it's good for ladies watches. The ones I have are mens, or boys I should say as they are around 30 mm diameter IIRC (here we call them cadet, I don't know if that's how the small men watches are known in the rest of the world).
But I love Seikos and everyday I love hand winders more and more, so I've got several 6602 too, and the latest was a 2220, a very tiny movement at 28.800 bph.
Here's one of my 66's
Edited by aac58
Man, that really looks good!!! I like it. There is a little antique shop near my work, she has a bunch of watches,  Elgin, Geneva, Bulova,  Hamilton,  Walther, some are old , very old. Im slowly picking through her stock. I picked this Seiko and a Elgin pocket watch for 50 bucks. And this Seiko is working great! Thx for the info brother!
Of all the choices you mention why Seiko?  and if Seiko why not chrono grades KS?  Worth every penny.
Some ole high grade American made pocket watches should still be there to find.
10 hours ago, Nucejoe said:
Says Move japan, nothing to be proud of.
I don't suppose you've ever seen the movie back to the future there's a reference to Japan in making crappy stuff in there? While Seiko makes interesting watches and we may sometimes look down on Japanese watches they've become collectors items. Fortunately they're not collectors items to everybody so if you're lucky you might Be able to find one cheap.
Although looking at eBay anything that resembles a outstanding Seiko I'm not the first person to notice it and they have much much deeper pockets than I do.
https://www.watch-wiki.net/index.php?title=Seiko_6600
Thank you!!! Appreciate the info!!!!
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
    • one of the problems we have is visible versus invisible. For instance millennium disulfide another high pressure lubricant black in color. I was told by somebody worked for the Boeing company that they had a piston like device somewhere that has eight call it around it to grab it so it has to slide and in the collet has to grab. But if somebody puts that type of dry grease on where grease with that in it it embeds itself basically in the metal and they have to throw the whole part away they get use it all. So I suspect on all the dry powdery lubricants that they will go into all the basically microscopic cracks and crannies of the metaland that's where it is visually at least until you scrub it off your visually going to see it which is good because you want your lubrication the stay word is. But I'm sure it doesn't last forever on the metal it's just a really nice lubrication
    • Thanks for the info. I can't seem to find tech sheets for those either.  I'll muddle my way though 🙂
    • Ohh spooky I have just aquired the same one mike, but mine has a drill bit inside it.
