Pocket watch.
1 hour ago, Alexandros said:
Hi, so I just bought a broken pocket watch to learn a bit. If i push the button next to the crown and I change the time forward the mainspring starts running but if I wind it it won’t doe anything, does anyone know what I have to do?
O boy.. Let me try to explain.
When you push and hold that thing with your thumbnail it allows you to move the hands forward or backwards. When you release that thing, you should be able to wind your watch by spinning the winding crown in one direction..
If it does not work that way, you may need to disassemble your watch partially for inspection.
Edited by Poljot
If the seller promised that it was working, return it and ask for a refund.
Otherwise if you will try to repair it yourself I wish you better luck than with the Seiko you have asked about previously.
There are two possibilities,  As Poljot said, The mainspring is broke or the spring is off the arbour in either case you will have to remove the barrel and have a look.  It looks like a cylinder movement so be careful with it people who can fit new tampons are thin on the ground,.
2 hours ago, Alexandros said:
No no the seller showed 10 or so and said idk if they are working, there was one which was working but I didn’t like it.
so I taught maybe I could fix this one but yeah rip lol.
Of course you can with just a little effort. The good thing is that you do not need a timegrapher to fix this watch. Just a screwdriver (-s) at this point and a new mainspring later... There is always a chance that the old mainspring could be repaired (not recommended )
I'm proud to fall into that category but I still depend by my mentor's stock. And since the OP wrote that he can wind the mainspring, that is the most likely failure, - a broken pivot. A broken mainspring cannot be wound.
Sorry for being somewhat OT but I thought I'd take the opportunity to ask about what signifies a cylinder movement.
Looking at this video it would seem that what signifies a cylinder movement is its escapement, the way the balance interacts with the escape wheel teeth. That part on the staff is obviously called the "cylinder", hence the name of this type of movement, yes, no?
Now, the word "tampon" I associate to something quite different than watch movements. Is that slang for the cylinder part or something else?
Edited by VWatchie
5 hours ago, watchweasol said:
Hi jdm  if you fall into that catagory you have my admiration as there are not that many who will even attempt to fit tampons as it takes great care.
It is not that difficult but is a case where one really appreciate having ready top quality tools like a Feintaster micrometer, a complete staking set and of course the small stakes for tampons. They come however in hundreds of sizes so you must have a vast assortment, then some refinishment may be expected to the total lenght ot pivot shoulder.
3 hours ago, VWatchie said:
Sorry for being somewhat OT but I thought I'd take the opportunity to ask about what signifies a cylinder movement. Looking at this video it would seem that what signifies a cylinder movement is its escapement, the way the balance interacts with the escape wheel teeth. That part on the staff is obviously called the "cylinder", hence the name of this type of movement, yes, no?
Yes a cylinder movement uses a cylinder escapement. As watchweasol correctly said, the tampons are plugs in the ends of the cylinder which are also the pivots. As the cylinder is drilled through (thus a cylinder, haha), plugging the ends is the only solution. Tampon is French for plug.
I've never had a huge assortment of tampons or cylinders, and always figured that by the time I sorted through and made whatever modifications necessary I could have just made a new one so I do that. Cylinders are a bit of a pain to make, the tampons not so bad. I do have a large assortment of cylinder escape wheels and wouldn't want to try making one!
    • Moved in. Now working out the best place to have things so moving around the room makes sense. The wooden movement testing rig may end up being suspended from the roof with some pulleys and ropes that I salvaged from some alfresco blinds that we replaced. I always seem to salvage things from things we scrap thinking, "I have an idea what I can use these for." I hope I'm not the only one that does that. My wife hates me for it. "What are you going to do with all this crap?" Anyway, here you go. If anyone has suggestions for workflow around a room, speak up. All Ideas are appreciated. The bench on wheels will carry either a laptop or my Samsung table for using with the little camera that is on the tripod for photos while dismantling etc. The small bar fridge in the corners going to have water etc in it and I might move the coffee maker from the kitchen out there as I am the only one that uses it. I want to get an ultrasonic cleaner so I may set up some sort of cleaning rig in front of the glass of the sliding door. Where the grandmother clock is currently standing. I'm hoping that I will be able to transition my working area, which is the table that the stool is sitting in front of, fairly easily between clocks and watches. I'll be doing my best to make sure that tools for each are separatedwhen stored. Logistics. I'll have a bit of wall space for being able to hang clocks if I find some that I wish to keep or hopefully at some time to be able to hang customer clocks for monitoring after servicing/repairs. The clock on the left in the blue pillow slip and the grandmother clock are earmarked for  Jarryd and his wife, Sara. He helped me move the benches in today. And then went on to tell me that ticking clocks drive him nuts. Who doesn't like the rhythmic ticking of a clock? I have a green pad for adding to the bench for a working surface. It is not a cutting mat or one of the Bergeon mats. It is actually a green desk writing mat. Was really cheap and will do exactly what I want, I think. I also have to get the sparkies back that put our new stove in to put some power points on the walls behind the benches. Hopefully this is all going to go well. I'm excited about it. It'll beat having to live out in the garage doing it. The other thing I have to do is cut a circle or square of plastic to go over the bouncing watch or clock part black hole in the middle of the floor. I would pretty much guarantee that anything that sproings off the bench would end up going straight down that drain. 😄      I think I have been on this forum about 4 years and still yet to really strike a blow. That's a bit sad isn't it. Signed up to Mark's watch course and have yet to buy the movement for working on. Have most of the tools I think I will need so now all just a matter of will.
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
