Station Clock?
Warren
Hi everyone
I have had this clock for years and would like to  know the type where it was made and approximate value
It has a double face and I brought it from an antique shop in New Zealand
The face is 480mm and the clock overall is 620mm
thanks
Warren
Its an 8 day fusee on chain timepiece, looks like an anchor excepment, job to tell by the photos. Pillars are suspect  no shape to them, look modern. Until I see the back plate I can't comment on the movement. There could be info stamped on the plate which might help.
There where  quite a few suppliers of public clocks to the government H.Williamsons, Smiths, Gillett and Johnston, Elliott and Stockall and Marples.
The clock is not a Gillett and Johnston the pillars are too plain, H.Williamson and Stockall and Elliott used plain pillars you should look for stamps on the case which would consist of the maker, year and Royal cipher the backplate of the clock would also be stamped with these markings.
The following is a Stockall:
https://www.sellingantiques.co.uk/648154/rare-edward-viii-mahogany-double-sided-clock-stockall-marples-1936/#
The problem with these Fusee clocks is that they have been widely faked in India but I have never seen a double faced fake, but there are also things about this clock that point to it not being quite right, the placement of the hinge for the bezel on the top does not conform to what one would expect which is usually hinged to the right.
The only way to confirm would be to remove the movement from the clock, to do this you would have to remove the hands from the side of the clock without the winding hole, remove the two screws on the base board (another thing that I've never seen on one of these clocks)the side with the winding hole will have screws around the edge of the dial remove these and the face and movement should lift out.
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
