helvetia 35 movement replacement part question
Looks like it was part of the case. Old watch cases never had those spring bars. The only thing you can do is drill the holes so it will take spring bars.
Looks to be in good condition, and fairly modern. I've never seen a bent regulator arm like that. Also the click is in an odd position. Should make identifying easier. I found a comment suggesting that Cortebert are known for curved regulators
I can't wait to see. I'm hoping for something good. I just hope it's not one of those bleeping FHF 96, as in the Mumbai Specials 🤣
@mikepilkThank you for your reply. Here is another picture.
Might be able to identify it once the diameter is given and a photo of the keyless works but no guarantee. Ancre-----Lever escapement Levees visibles---visible (jeweled)pallets Double Plateau-----double roller Spirale Breguet--Overcoil hairspring Balancier compense----Compensated balance wheel 15 rubis---15jewels
