FHF 175 Mainspring
mcoulton
Hello
I don't have very much experience with mainsprings and I've just removed one from a FHF 175 movement. As you can see from the picture it's still coiled up. Any video's I've seen always show the mainspring almost unwound. Is there an issue with mine and should I see if I can order a replacement?
Thanks in advance for any help that can be provided.
Michael
As you noticed on that tired mainspring, it should have an "S" shape.
This one at Cousins will do the job, it's a little shorter than what's listed on Ranfft but that won't make much of a difference
1.45 x 0.10 x 300 x 9 Non-Automatic
GR3953
If you get another FHF175 donor movement it might have a similar old mainspring, and you'd need a mainspring winder to put in into your barrel unless you just swapped the whole barrel over, unserviced. As you've probably seen, the new ones come in a package so you don't need a winder. New spring is much cheaper than a winder, until you're replacing lots of mainsprings.
You can fiddle with some of the other dimensions when finding replacement springs, if you can't find new or NOS fits, but the next shortest spring of a given size is usually the best bet.
4 hours ago, Michael1962 said:
Width x thickness x length x ‘I don’t know’ but I think it might refer to the length at the barrel end of the spring that is doubled back on itself. The bridle.
Almost there- height (most used term, width is probably ok but might get confused with thickness) x thickness x length. The final number isn't always given but it refers to the inside diameter of the barrel.
Relevant to choosing another size, these are generalities:
the mainspring barrel size (last number, 9mm ) is the size that the new mainspring is packaged. You press it into your barrel. Must be equal or smaller than the ID of the barrel you are fitting a mainspring into. Smaller is OK, it will expand to fill the barrel when inserted.
Length (3rd number, 300 mm) should be close to the number specified. Shorter is OK, probably just a little longer is OK also. Corresponds to the power reserve, how many hours the watch will run on a full wind.
Thickness/Strength (.10mm) is the thickness of the metal spring. This represents how much power or torque the mainspring will deliver to your movement, if the width, material and age of the spring are the same. Thicker will deliver more torque, eventually resulting in a higher amplitude of your balance, eventually leading to overbanking. Thinner, low amplitude, poor performance. Condition of the movement, the gear train, number of complications, oil condition, will all effect how this effects your movement.
Width/Height (1.45mm) this is the height of the coiled mainspring so it must be smaller than the inside height of your barrel. Next size smaller (-0.05mm) here shouldn't be  a problem, the spring will be marginally looser in the barrel, otherwise it should be fine. Technically you would want to compensate for the reduction with a thicker spring, to keep the torque the same (essentially keeping the cross-sectional area of the spring the same), and there is a formula to calculate all this, although you'd probably be fine without engineering the replacement, depends on how fussy you like to get with <1% differences.
You shouldn't have to change more than 1 of the length/width/height values to find a replacement for an unavailable spring, usually the length being the easiest and least consequential in terms of effect on the operation of the movement.
You may also find an older Dennision/White-A-loy numbering system for mainsprings in the Bestfit catalog and elsewhere, you can use to find NOS mainsprings on ebay. There's  lookup tables to translate it to metric. Your target would be "511M" or  "511K"  I believe (where the letter is the length, M=317mm and K=292mm ). I'm not sure about those, there's usually no cost savings, and who knows how old they are or how they have been stored, but they are available.
On 12/27/2020 at 2:11 PM, mcoulton said:
Hello
Michael
Hi there,
This is how almost every old carbon steel mainspring looks like. These are pre-1960-ish production mainsprings and they never looked as S-shaped, not even 60 years ago, not 150 years ago or ever. The newer alloy springs do look like "S". I would not recommend getting NOS carbon steel mainspring. It may be waste of money and it can break at any time.
Thanks to everyone for their responses. It's been quite an education! My plan is to try and use the existing mainspring and see what the response is. I've take a time-graph of the movement before it was dissembled and cleaned. Once I've reassembled it and put it back on the time-graph, I'll have a better understanding of where the project is.
Michael
Quote
The logical implication of the BHI statement about the potential damage that a broken mainspring can cause is that if the spring hasn't already broken you are lucky, and that old carbon steel springs should always be replaced with a modern 'unbreakable' type.
Edited by KOwatch
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile and is supported by the literature:   A review on control of droplet motion based on wettability modulation principles design strategies recent progress and applications.pdf   However the hole point is that we have less mobile oil so an oleophobic  would see to be the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic (beading) and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
