Identifying clock
MechanicMike
1 hour ago, MechanicMike said:
Except now, i'm wondering, "How the heck does he get his stuff so clean and shiny?"??
Polish, degrease, ultrasound and wear gloves. ?
The secret to getting an anniversary clock to run is using the right suspension wire at the correct length. Then getting it in beat. You'll need to work in a very quiet environment as the ticking sound is really soft. ( or I'm really getting deaf! )
Good luck!
Hi Hector  they are very light on the tick/tock  I have a pizo disc attached to a croc clip a couple of foot sheilded cable (headphone cable) that plugs into an amplifier that does the trick. Although setting up an anniversary clock relies on the spring and the pendulum over swing and like most clocks the escapement, they can be frustrating.
On 1/26/2021 at 10:57 AM, watchweasol said:
Hi Mike  not unless you are a bit deaf like me?, I have lost the top end  so I find the Amplifier useful.  I think the important thing is setting the escapement using the Grid for you to copy in the book, and watching the over swing.
I'm ALOT deaf! but I have the grid already made out, and the regulating tool came in. After the last brain freeze I managed to get it all assembled and am closing in on the suspension unit and setting it. I've noticed my minute hand is a little loose with play. is there something i can do to snug that up? add washers to the tension washer or something with the tension washer itself?
Edited by MechanicMike
wrong word! minute, not hour!
You say the minute hand is a little loose with play. Do you mean it flops about or say just past the hour it will drop down to the 6. The hands on these clocks are not meant to be really tight like on other clocks, if they are to tight the clock will not work correctly it will even stop. If the hand just drops say a minute then yes a washer can be the answer, are you sure you have all the washers in place after you took it apart and you haven't misplaced or even lost one.
Yes, the minute hand just seems sloppy and does move about. About 2-3 minutes either side of 12. It doesn't drop tho. Understood the hands aren't to be too tight. Got it. I may have discovered the issue: the tension washer had a groove or dent in it where the tapered pin rests. I rotated the washer and it snugged up some. I'll see if that works.
Hi Mikeas Old Hippy said its ok but not too tight, Is it a domed washer being held on by the pin if so a very thin washer will do ok.   You will find that tool indispensible when working on 400 day clocks.
I put it up on the saddle and I can see right away why this tool is a must, and why not to use needle nose pliers. It's very obvious! ??
I think the groove in the domed washer was the problem. It wasn't creating enough tension. Moving forward! So close!
This is how you use the tool. Where you have the fitting for the top block that holds the suspension spring, The tool is clamped around the outside of the whole block that holds the suspension. That part is friction tight, because the tool has a long handle you are able to make tiny adjustments to the beat.
without question. it is a must-have.
I began to install the suspension spring and spotted a problem-when trying to attach the pendulum it seems to rest at the bottom of the cup and I'm not even close to attaching the lower block to the pendulum yet, giving the appearance of the spring being too long. it's the correct one according to the book and matches the chart. the tubes or rings they call them, don't appear to be mushroomed and the base appears flat. Went thru chapter 8 Q & A's and didn't read anything else regarding this? do I need to shim up these tubes or (I hate to) shorten the spring?
Are you sure the back plate matches to the book don't forget the screws placement they are shown in black it should all be in the same place as your back plate, when you have the top and bottom blocks in place fit it to the movement and hang the pendulum and see if it is clear from the cup, you should be able to lock it for moving.
Hi guys-I had examined the back plate closely, holes, black dots and all, just for that reason and I will check it again when I get home for accuracy. If I were to have to trim the spring, on what end would it be?
Measure twice cut once-you how many times I've measured stuff 20 times only to find out maybe I should have measured it one more time???
Hi Mike  What model Kundo is it and I will have a look in my book in case there is a typo.  Which end does not matter just tale enough off so that when the blocks are fitted the pendulum clears the cup allowing you enough lee way to lock the pendulum for moving the clock.  One thought tho is that has this been dismantled before and washers have been left out of the support columns as that would effectivly reduce the height of the clock giving you the exact same problem you have now as the clock head is too low.  Before cutting the spring just for the hell of it raise the height of the head and see where that leads as once the spring is cut you cannot put it back on.  Nothing to loose.
I have no idea of the history of the clock except it was given to the owner by her grandmother when she was little.  I haven't cut anything yet. I'm measuring for the 22nd time...by my account, it's plate 1389?
Hi Mike  had a look at the book, It does indeed look like the right one all the holes correspond. It quotes .0032mm (.081mm) Horolovar      units 1 and 3A          Kundo standard 49 and standard 53 both using the same suspension. In fact all the stardards use the same.
On some of these clocks there are polished washers under the support legs and at the top of the columns for decoration.
    • What works for me (waiting for the villagers to assemble with torches and pitchforks) is to put a liberal (in watch terms) spot of 9010 on one of the pins of the pin pallet, this seems to improve amplitude and beat error.
    • Non-magnetic is a poor description of such a hairspring. A better description would be unmagnetisable hairspring. There are metals and alloys that are attracted to magnets, but don’t become magnetised themselves. A hairspring made out such a material will be attracted to magnetised tweezers, but will not become magnetised. These hairsprings can be disrupted by being in close proximity to a magnet, but the disruption will cease the moment the magnet is moved away. These are hairsprings that could conceivably be disrupted by a magnetised hairspring stud. Best Regards, Mark
    • More than enough. Here's mine at the height I work at. I think the working distance with the included 0.5x Barlow lens is about 9".   So yes, that halves the magnification. The full story is the objective lens goes from 0.7x to 4.5x. The eyepieces are 10x, giving you the advertised magnification of 7x-45x. However the working distance is unacceptably short, so it comes with an 0.5x Barlow lens, reducing the magnification range to 3.5x-22.5x, but giving you a good working distance. What I did was buy a pair of Extreme Widefield 20x Eyepieces for when I need more magnification. You keep your high working distance, but get your 45x magnification back, at the cost of some width of field.
    • Modern ones after blue steel, invar, elinvar and nivarox , the shiny one are not supposed to become magnetised. But i have had them jump to tweezers. And i dont really understand the comment that what can be magnetised is the stud carrier and rate regulator and they can attract the hairspring ? If the hairspring is non magnetic then how can it be attracted to something else thats become magnetise, its non magnetic , that doesn't really make sense to be ?
    • Does it say 17 jewels on the dial or on the movement ?
