I'm Moving to a different building at the same complex and will have a nice room next to my office just for watch repair.  Their is a concrete floor now.  I plan to caulk between the floor and walls and paint the floor.  Question is do I paint it white or another color for easy finding of parts?  Any other advice before moving in?
Get into a habit of using Rodico or two sets of tweezers, or a pair of tweezers and a peg-wood stick to hold the part in place while removing or installing it. Sometimes you can use a small piece of plastic wrap on top of the movement during disassembly of certain components. It's clear plastic - you can see things and the parts are not going to fly across the room.
Back when I was planning my home office I was tempted to lay artificial grass instead of carpet.  It would have been like working outside under the shade of a tree in the summer breeze.  Try that.
I would not like concrete floor in a rough mechanical shop, and it would drive me crazy for a watchmaking or any other precision shop. I do not know what kind of climate you have but just an average winter would make expensive and difficult to geet a comfortable temperature to work in. Anything else from the cheapest wood flooring to linoleoum or tiles would be better.
I think that a "brown" color was suggested in the book I'm reading.
So, perhaps cork? It's somewhat softer; low bounce for parts, and provides that contrast for shiny parts. But you can still roll an office chair on it.
Or maybe have the floor re-poured like a shower floor, with a big magnet at the low spot?
I am putting a box of sand under my desk so I can take off my shoes and wiggle my toes like I'm at the beach.
Go all the way then
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
