how to remove scratches from watch
ronak
I'm a dentist. And I've never had much success polishing watch crystals with toothpaste.
The best polishing hack I've found was using those foam nail buffs that the ladies use. There are some sets that come with 3 grades of abrasives. Use the coarsest one first, then move the intermediate when all the deep scratches are gone. Finally use the finest grit to get a shine. As a last step, you can use a tiny smidgen of Polywatch to really bring out the shine.
How about the stuff dentists use to polish teeth after a clean?  Polishes teeth shiny.
What is that stuff called.  TIA
joe
Just done an acrylic one this afternoon - in a few minutes.
If the scratches are deep, start with 1000-1500 wet and dry. Then switch to 2000, and finally 3000.
Then I use acrylic polishing compound on a cloth. Worth buying some of this - it always surprises me just how well it works
It's surprisingly easy and quick.
If the scratches aren't deep, then some acrylic polish on a cloth - only takes a minute or two
(you can buy an assortment of fine wet and dry, and acrylic polish from ebay)
Edited by mikepilk
I've found very good results so far using the abrasive pads in the Turtle Wax Headlight Lens Restorer Kit. They're a great size and stiffness. The most abrasive works quickly on the deepest scratches and there are three additional, decreasingly abrasive (higher grit) pads in the kit that get it down to see-through quality. I then finish it off with Turtle Wax Headlight Cleaner and Sealant. I had these around and they've always worked, so I haven't tried anything else. But, Polywatch appears to be the first go-to for most people; however, I've always wondered if it worked efficiently on deep gouges/scratches.
It probably will, but you will need to put on a lot of elbow grease.
joe
It's called prophylaxis paste. But that is actually quite abrasive. It's better to use the stuff we use to polish acrylic dentures with. And that's called a very technical name - polishing paste.
I find using sanding pads better than using my denture polishing lathe motor. The felt wheels and bristle brushes that we use tend to leave microscopic lines in the actylic. I only use my polishing lathe with a wool wheel for the final shine.
Acrylic watch crystal are surprisingly soft. It doesn't take much elbow grease to polish out deep scratches.
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
