Glycine Airman Hacking spring
Hi everyone,
I am putting together a Glycine Airman SST. This is the model with AS movement and a tiny "hacking" spring/pin on the movement ring that I know is supposed to "pop" through the dial when the stem is pulled out, thereby stopping the seconds hand. Does anyone have any tips, tricks, or general direction on attaching this spring/pin through (around?) the stem and through the dial? How far is the spring supposed to stick out the dial when the stem is pulled in? I'm really not sure as to the exact shape it's supposed to look like upon assembly. Any help is appreciated! I have attached a photo of the spring as it looks now.
2 hours ago, Nucejoe said:
This shows an eta movement, OP says his watch houses an AS calib.
Noted ... I'd taken this to be a general question around this type of Glycine hacking feature, pin sticking out length and so on and was under the impression this was a solution that Glycine retrofitted themselves rather than it being a standard AS, or other manufacturer, hacking feature. I'll look out for further updates with interest!
Edited by WatchMaker
The movement is AS 1902/1903. I have attached a photo of the movement, one of the stem with the "indent" where the pin is supposed to attach, and one of the dial with the hole at 12 o'clock where the pin should pop out of.
The gentleman on this link goes into detail about this type of hacking mechanism, but I'm still not sure how the pin should be shaped, ie. how it is supposed to attach to the stem and how much should it protrude out of the dial when hacking is on or off.
https://www.nevadawatchrepair.com/glycine-airman-service.html
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
