1 hour ago, Tudor said:
I’m guessing it would use two escape wheels
Only the one.
If you google Seiko Calibre 9SA5 there's a fair bit of interesting stuff out there.
or...
That's cool.
Looks like 450 degrees of balance wheel rotation, at high beat! Crazy! I was not expecting more than a full rotation, but that probably adds to the timing accuracy.
Definitely different from the coaxial escapement. One of the big issues Daniels had with getting the coaxial ready for mass production was alignment of the two escape wheels (Smith, his protege, addressed this by making a more three dimensional wheel that is indexed during manufacture). This solves that, making it easier to mass produce. It reintroduces some sliding friction though, as the last jewel on the escape pallet is a fairly conventional geometry with a Swiss lever-like impulse face. Not only is that sliding friction itself a bit of a compromise, but the lubrication requirements also reduce the service interval compared to a coaxial, whose oil usage (at least on paper) is mostly for oxidation protection. The low tooth count on the escape wheel is interesting. With 8 teeth at 36000bpm, it's turning pretty fast. I count a total of 5 wheels between the second mainspring barrel and the escape wheel to make that reduction work. The losses added by those two extra wheels aren't super exciting. I'm not sure how the extra amplitude plays out; I've not read too deep on that subject. As I recall, additional amplitude reduces error, but only to a point. I'm not confident enough in that recollection to say anything definitive though.
The coaxial escapement eliminated a significant percentage of the Swiss lever's sliding friction losses, did not require any additional wheels and their requisite frictional losses, and managed to dramatically increase the service interval in the process. This dual impulse escapement cuts the sliding friction nearly in half compared to the Swiss lever, but adds back an appreciable percentage of it through the two additional wheels. Further, I wouldn't go so far as to say it doesn't increase the service interval at all, but it wouldn't likely do so by much. The coaxial is a definite improvement, where I feel this is more likely just novel. The asterisk is the amplitude (at least as presented in that animation); maybe a meaningful improvement, maybe not, maybe just an animator who didn't know better.
I am very impressed with these Grand Seiko's however no parts are available if one lands on your workbench. I had to replace a shock spring on a Rotary watch that was fitted with a Seiko movement but no shock springs are available so I had to modify a shock spring I had in my stock.
Unfortunately, there's no "free lunch".
But, I have always admired the Seiko and Zenith high-beat movements. I think they're fantastic, and I aspire to own a high-beat El Primero some day...
I have a plan to coat a conventional 2824 escape wheel with DLC (diamond-like carbon) which is very slick and of course very hard. This may allow the stones to be run dry, which should free up some losses to oil sticktion on the stones. Of course the escape wheel may then cut into the stones.
I can also have the going train wheels and pinions coated (perhaps pivots too) but I'm not sure of the implications. This (pivot) change may require sapphire bearings rather than ruby. Not sure. But, it too may allow it to be run completely dry, which would not only reduce the drag, but allow a much wider operational range (much lower-arctic and/or space service) without special oils. Maybe.
I don't know enough about the micro-mechanics so I want to base it on a well-known movement with tons of empirical data available. That old 2824 seems like a good choice (although I prefer the 2892-A2). Plus there is the very real possibility of parts loss or damage in the coating process, so something with an easy parts supply also makes sense for this. Maybe a cheap 2824 clone movement would be an even better choice, as I can buy three for the price of one ETA.
Thinking...
6 hours ago, Tudor said:
I don’t have any more details.
I’m guessing it would use two escape wheels based on this illustration.
Smart design, takes two impulse out of one wheel and three pallets or are there four? Again much like co- axial little run on escape teeth.
Which being honest is very unlikely. Just some Swiss watch owners, Grand Seiko owners actually appreciate the exclusiveness of having their watch sent to the factory for service or repair.
Quote
Strange because 7S26, 4R15, 6R15, NH36, NE15 etc shock springs are easily available from Cousins.
That is correct but the latest Seiko calibers have unique shock springs. They look like standard shock springs until fitting as they slightly different in size. I did put up a post a while ago with this issue.
Topic below? That is a Chinese movement, not a Seiko. For these, one could try the assortment that Cousins sells for the purpose.
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
