Fusee English Lever Pocket Watch Reassembly - Part 1
As promised, here's the reassembly of the watch who's fusee I posted photos of:
First, here's the bottom plate with the fusee, centre wheel, lever, escape wheel & 4th wheel in position:
and the fusee ratchet paw on the top plate:
The plates are joined & pivots located in their holes & pins replaced. (This watch was a non-runner when I got it & the lever had a rather badly bent pivot which I straightened & I'm hoping this was the only problem stopping it running):
At this stage it's best to fit the 3rd wheel bridge, solely to protect the 4th wheel pivot which also has it's hole in the bridge:
Next fit the barrel:
and the barrel bridge:
Next the fusee chain needs fitting - the hook end goes in the fusee & the pointy barb end in the notch on the barrel
Apologies but it's not possible to photograph the actual chain fitting, but after fitting fit the blued steel barrel ratchet, add some tension (say half a turn of the ratchet) then screw in the ratchet click to hold it in place:
Now fit the 3rd wheel & replace the bridge:
At this point it's worth winding some chain onto the fusee & check that the lever snaps to & fro with a little movement of it with a cocktail stick...this shows that power is getting through the train. Then the balance wheel can be fitted - the staff has a safety roller & jewel peg like a Swiss lever escapement:
Here the balance cock has been fitted & it's ticking nicely
Part two will come later when I'm satisfied all is well which will take a few days of windings...I'm not 100% happy with it at the moment as after running for a minute or so it kept losing power to the lever & stopping...having said that, after some fiddling it's running now...it could be that the fusee is not giving maintaining power...if it continues to play up I'll have to strip it down again & investigate....anyway, hope that was interesting!
  • Like 6
You're doing an excellent job David, both on the watch and the walkthrough. I have two pocket watches that were my fathers, this put me in the mood to do a bit of antique horologising! :)
I'm sure I read that children used to make the fusee chains as they had good eyesight, maybe someone else could confirm this?
It wouldn't surprise me if they were involved Roger, fusee chains were made using cottage industry in the early days. Edited by Geo
That's true so the story goes....frequently by candlelight I heard!
I once repaired a broken one by re-riveting links & suddenly developed enormous respect for whoever made them....even with a decent light & a loupe my thumb looked like a raspberry afterwards from hitting it & the swear-box was full.
I believe there's a book called "The chain gang" describing the fusee chain industry which I'll treat myself to one day.
Funny, I'm working on one right now. Both the mainspring and the hairspring are broken, not sure how to source parts for such an old watch, but it's part of the fun :)
Anyways, do you do anything to the chain before putting it back ? Is lubrication of any sort necessary ? How about cleaning ?
Hi!
I tend to pick up old movements off eBay to harvest parts from, it's the only real way. There's a website oldwatchparts that sometimes has parts. I've made the odd simple part from filing an old bit of steel but wheels, staffs I wouldn't know where to start with!
The chain I soak in petrol for 24hrs then oil with clock oil...I wouldn't know if that's "correct" as such but it seems to work. A really stiff chain needs longer soak & slow gentle working in of oil afterwards. Be careful & work the oil in with the edge uppermost otherwise the chain can become concave.
Hope that helps!
  • 1 year later...
A nice step by step with good pictures. The pivots on these watches are very important in order for them to run well they need to be burnished. Don't expect the balance to rotate the way a modern watch would these old pocket watches are quite slow in rotation.
I always cleaned the chain in the watch cleaner and I would oil it by running it through an oiled piece of old clean cloth.
Nice pics and well done.  Getting the main plates together is very tricky indeed and much patience is required!  I know as I broke a lever pivot on mine and still not got a new staff made.
I found the following book very helpful for all stages or disassembly and assembly of this type of movement. It has a full chapter on English Lever Fusee Movement
THE POCKET WATCH by Christopher Barrow
Edited by canthus
    • Just got these good quality diamond files from the bay for Just a fiver, we all love a bargain dont we. Brand names are J.K.Smit  and Triefus, two old diamond tool makers so not cheap crap.
    • Its a touch under ive just remeasured it and added a wrist shot. Unbelievably it was £13  plus 3 postage. You dont find watches that nice for that money every day of the week. Maybe removing the epilame in the oil region improves the purpose of it. We may know very soon as i emailed Episurf 4 hours ago to ask that exact question. 🤞they are happy to provide an answer for us. How do you fancy trying a stearic acid vapour treatment experiment  H .  Shall i have a go this afternoon ? Stearic acid experiment underway,  its started to melt at around  65° C. The idea is to find a large cap jewel to suspend over the vapour release.
    • That's the size of my grandfather's Ernest Borel watch. Definitely not a lady's watch! 👍
    • Thanks H It does have a big crown for the watch , it could be considered a ladies watch these days i guess, it measures 33mm case 36mm with that large crown 18mm lug space. A tad small for a guy of today, but still very wearable. The photo was deceptive so here it is adorning my 7 1/4 " wrist. It need some love to make it run better. The hair coils are touching so running a bit fast at the moment,  not caused by magnetism, and maybe just a clean and a service. The dtal is in fantastic shape.
    • That's one beautiful timepiece! Love the big crown in proportion to the case. Perhaps a ladies' watch, but I don't think so. I have a "modern Ingersoll" watch, but it has nothing to do with the original brand (Miyota 9015 movement). Interesting synonym for synthetic oils! 😆 There is, of course, a limit to how large a volume of oil epilame can bind and hold in place. If the oleophobic effect is too strong then it can become a problem. I'm not sure where I heard or read it, but as I understand it, the active ingredient in a bottle of epilame is extremely small and more than 99% of the contents of the bottle is just a transfer agent. If the active ingredient becomes too concentrated, which it can become over time, or if the product is of poor quality, the oleophobic effect is amplified. This in turn causes the applied oil to look like a gummed-up ball on the surface of the treated part. If that happens, we know that the active ingredient has become too concentrated. What we want is for the oil to bind but not to the point where it is formed into an excessively round ball on the surface. The highlighted text in the patent that you refer to describes well the problem that can arise with too high a concentration of the active ingredient. However, I would be extremely surprised if the entire amount of oil leaves the treated surface as water on wax would. At present, I am convinced that the analogy between wax and water on the one hand and epilame and oil on the other is incorrect. Epilame is described as binding and that is also my absolute experience. Epilame probably has some repelling effect but that is not its main purpose and that is not how epilame is designed and works. The method of abrading the epilame treatment from the section of the pallet stones coming in contact with the escape wheel teeth seems after even more research to be well established, but if it actually works, if so how and why is beyond what I can currently understand. Perhaps it is just to do and trust that it is based on well-established experience. I am, after all, inclined to think so.
