Clock trademark help
Stuart2
This mark is attributed to a company called "Gerbr Rechiel" in the town of "Markt Dietenhofen, Germany"
thought to appear also on some "Germania Regulator Factory" clocks so probably taken over by that company at some point.
There is no information other than trademark origin that I can find.
3 hours ago, oldhippy said:
Thanks wls1971, I couldn't find a thing about the makers mark.
I use a number of books by Karl Kochmann, his best known is "Clock and Watch Trademark Index of European Origin" well worth seeking out his books for anything German he was meticulous in his research of German factories and makers.
3 hours ago, Stuart2 said:
unfortunately the clock had worm so i took it apart and treated it
German Vienna clocks seem very susceptible to worm it's the soft wood, I bought one sight unseen at auction once it was absolutely riddled with worm, I now use Rentokill wax polish once a year on my wooden clocks.
  • 4 months later...
I've got four Vienna's on my wall I have to hang them so far up the wall I need a step ladder to wind them, I have a cat that see's every thing I hang on the wall as a challenge that must be met, thankfully she not a scratcher, just has an eternal quest to reach the highest point in any room.
16 minutes ago, watchweasol said:
The curtains are not safe then? and best not keep a Budgie.
11 minutes ago, Stuart2 said:
I bet she loves cuckoo chains
Her favourite spot is on top of the bookcases in the living room the route is across the top of all the clocks on the mantle piece, jump onto a grandmother clock and then onto the book case her route down is much more direct straight onto the sofa from height which is not so good if I doze off on it.
The case looks much better the colours evened up nicely what did you use have you just waxed it ?
It was originally treated for woodworm, then thoroughly cleaned then i used liberon medium oak black bison wax and plenty of elbow grease. The movement was really well made, dead beat escapement with maintaining power, just required new lines and a strip down and clean and probably one of the only clocks that i have done like this that did not require any bushings. Really pleased.
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
    • one of the problems we have is visible versus invisible. For instance millennium disulfide another high pressure lubricant black in color. I was told by somebody worked for the Boeing company that they had a piston like device somewhere that has eight call it around it to grab it so it has to slide and in the collet has to grab. But if somebody puts that type of dry grease on where grease with that in it it embeds itself basically in the metal and they have to throw the whole part away they get use it all. So I suspect on all the dry powdery lubricants that they will go into all the basically microscopic cracks and crannies of the metaland that's where it is visually at least until you scrub it off your visually going to see it which is good because you want your lubrication the stay word is. But I'm sure it doesn't last forever on the metal it's just a really nice lubrication
    • Thanks for the info. I can't seem to find tech sheets for those either.  I'll muddle my way though 🙂
