Is this pallet fork over-locking?
margolisd
Just looking at the pictures your analyses are spot on, at a closer look the entry and exit seems to also differ in depth these should also be equal in depth.
If their not you get exactly as you say loss in amplitude.
  • Thanks 2
Now I tried to "adjust" them for you it should be something like this.
Almost the whole "chamfered" part of the club is locking the pallet at an equal depth at both entry and exit pallet.
The pictures are not good but I have made some cad drawings once upon a time from them you can get a feeling of how it should look like.
The plot thickens. The upper escape wheel jewel hole is badly worn. Way too much side shake. So my theory is that the escape wheel is leaning in to the pallets messing up the geometry. So I might change the jewel before I move the stones.
Edited by margolisd
Think that is a great start. One easily forgett to check jewels and pivots. And you shouldn't do anything to the pallet jewels until fixing the jewel.
6 minutes ago, margolisd said:
That’s great. I’ve been using Shapr3D. Which is an iPad app. It’s absolutely great to quickly “sketch” something. I use it before I jump on the lathe so I can quickly visualise to scale what I’m going to do.
That is just what I to do nowdays, technology sure makes it easier some times but then it comes down to the fingertips in the realization..
I’ll just add that it’s sometimes hard to judge from photos, and that the depth of lock didn’t actually look necessarily too deep to me.
From my experience with some older Seikos, they are sometimes a pig to get decent amplitude from, and I put this partly down to premature wear of the bearings (pivots or bushings). I tend to avoid them for this reason. But I don’t want to put other people off!
3 hours ago, nickelsilver said:
Don't forget to do all the escapement checks before you start moving stones. Drop lock, run to banking, fork horn clearance, guard pin clearance
this is a modern mass-produced watch the likelihood of the depths of the stones not locking correctly is almost nonexistent. If somebody  played with it and change them  yes they could be wrong. This is where it's really important to check everything else because there is probably something else.
There actually are rules on how deep locking should be but they're also dependent upon doing the escapement checks because they also control how deep the locking should be.
Then have ever heard a story about it Seiko that had super amplitude? The answer is no because it was never designed to run with a lot of amplitude they always have pathetic amplitude because that's the way they were designed. They even put oil on the pallet fork pivots one of those things you never supposed to do that kills amplitude yet they do it why? because for reasons that we have no idea they were designed to run with pathetic amplitude. That doesn't mean you can't tweak things like you can improve the regulation we could probably improve the amplitude but they weren't designed that way from the factory.
And 99.9% of the Seiko service manuals they never reference the amplitude except in one particular manual that is mentioned. 4006 a and I have it snipped out for you.
Interesting reading, my rambling will not be long, as I think @margolisd is a bright man who has ambitions to learn and take his knowledge to the next level and therefore asks for advice from a diverse group like this. I don’t see any problems in people wanting to learn and experiment a bit maybe he could tweak it to an amplitude above the normal.
I couldn’t agree more the most mass-produced watches leaves the factory with “good enough” specs standard Seiko’s is no exception, maybe more the norm, that is it keeps time within the given specifications and nothing more. It’s the same as with any mass produced product I would say.
Then there are products that gets tuned a bit above the normal specifications, these products are given a little more attention. Mostly they put in parts with a higher-grade material and finish in the escapement and balance system. Sometimes they even are adjusted in the matter of getting the perfect position on the jewels in the pallet fork in regard to length and height position. Sometimes even the pallet jewels are off by a hair, but works satisfying according to the specification, but one rectifies this error anyway. And so, it goes on.  I guess this is the tuning procedure margolisd is examining. I think too many nowdays is satisfied to just service the watch into just good enough condition.
Just to see if there were some different thoughts of this philosophy regarding the entry and exit pallets I took a small trip to one of my favourite websites this morning eager to gain new knowledge about this matter.
https://www.awci.com/watchmaking-excellen/drop-lock/
I guess the theory about the pallet jewels position seems to be the same here, which actually was margolisd initial question. There seems to be a drop lock issue.
But after a closer examination he found some plausible problems that would explain this possible issue with the pallet depth, hence why one should always do the  checks suggested by @nickelsilver before and after an effort to rectify the problem.
John makes some very good points. Especially the “mass produced” bit.
The only thing which I find far, far more common than incorrectly set pallet stones (or swapped lever with incorrect pallet depths) is misadjusted banking pins. This obviously only applies to those which can be adjusted.
In watch repair if it's movable it definitely should be moved. Banking pins are perfect example of that common in American pocket watches you have to check them every single time because somebody probably has moved them without a clue of what they're doing. But do not feel safe just because those banking pins are not movable there is a tool in case you feel they should be moved.
With all due respect, what is your training Mr. Margolis? I ask because I've encountered a number of school graduates both Swiss and otherwise, who were fairly clueless about adjusting escapements. I think in part due to what John has said above, and just a lack in the training. It's a really important thing, WOSTEP used to spend weeks on it in their fabled but no longer "Refresher Course" which was really just a mindf@ck of adjusting escapements and hairsprings for 20 weeks. Sorely missed now. I really want to put together a crash course for here, but time is the limit. Just did a ruby passing cylinder 4 tooth escape wheel duplex watch, remaking the missing oddball stopwork ring. Got two marine chronometers needing repivotiong and one a detent too. It keeps pouring in.
The good info that used to be easily found is disappearing- but the above linked AWCI stuff reveals a _lot_ of escapement info if you dig in. I will put something together in the next few months. I'd say I adjust the bankings or stones on 25%- 35% of what comes through. Much is 70+ year old stuff from a major manufacturer, and often those have solid bankings machined into the mainplate and stones cut so they bottom out on the fork slot- what a joy!
My experience with other students is that often they are not interested in theory. Not all, but many. I think it is literally a dying art, sadly. I tend to find that the clockmakers that I train alongside have a greater interest in the theory side. I suppose you really have to with clocks if you are making parts and adjustments regularly.
Fortunately, we will always have the fantastic books which have been written that cover horological theory in great depth, so it’s there if people want it.
  • 3 years later...
I have a similar problem. I was servicing a Seiko 6119 and after the wash I realized there was almost no shellac on pallets. I don't know what the shellac condition was before but I haven't had problems before with my wash routine. I do a final quick rinse in IPA but this time I used hair drier for some heat in the end. Maybe I melted the shellac? Gotta be more careful in the future. Anyway they were still perfectly level so I guess they hadn't moved. I did re-shellac them and since it was my try I applied a bit too much but not a total failure. I did the assembly and oiling and didn't reach more than 220 amplitude. I'd expect at least 250. Clean and assemble again, still 220 degrees. Then I realized there's way too much lock on exit stone and a bit less on entry stone.
The question is does extra shellac mass in pallets typically cause drop in amplitude? Locking problems definitely do. I haven't ever adjusted pallet stones but in a similar situation I have swapped the pallet fork with improved numbers as a result. I already dissolved the shellac off and try to adjust a bit and then shellac. I have a pallet warmer (the one that looks like a hammer). Any tips or online literature/videos appreciated. I've heard of a 1/6 ratio rule and my pallet contact/width ratio looks more like 3/7.
It's actually quite amazing how much amplitude you can lose if you walk is too much like yours is in the picture.
Technically the pallet fork should be light as possible to move really fast. But shellac isn't overly heavy. I would be more concerned if you had too much shellac and it was rubbing on something.
The problem with rules are there so many of them and it also depends upon the construction of the watch. Then we have other rules like this
The problem with your image is if you measure carefully it looks like your lock is about 50% which is much greater than it's supposed to be. How does it compare to the other side?
Then out of curiosity how did you lubricate the escapement?
The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.
Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
I experienced that different types of shellac and their ages are affected differently by IPA. Sometimes the shellac dissolves in a few seconds and sometimes several minutes are required. Nowadays I never let shellac come into contact with IPA. It's a hotly debated topic here on WRT if you search.
Like John, I don't think you need to worry about the weight of the shellac, but instead that it might start rubbing against something.
When I learned how to adjust pallet stones, I tried documenting my experiences in this thread. Hopefully, it can help you.
I personally don't believe in the idea of abrading the epilame before oiling so I don't think you need to think or worry about it. The only time I've heard anyone mention this is Alex on the YouTube channel Watch Repair Tutorials but actually no one else. I'm not saying it's "wrong" just that I don't think it's necessary or adds anything.
Edited by VWatchie
That's an interesting question which I don't think I've seen explained anywhere. But I think the problem will go away just about instantaneously. In other words the  coating is really thin and it should go away almost immediately. So the problem should resolve itself extremely fast.
Thanks for the help guys! VWatchie I already found your thread but I'll check it again. Nice to know about acetone, I still have to get the shellac off since I made a little mess. I adjusted the jewel, put new shellac (the so called soldering technique, pallet tool too hot this time so the shellac "wire" melted in air before getting in contact with jewels or fork) rinsed the pallet fork and put it back dry. Amplitude is now in the 240-250 range that I expected in the first place. I guess there's enough oil in the escape wheel teeth already but I'll check that later. The mainspring was pretty beaten so a new one would probably boost the amplitude even further. Nice to learn new things. Now I have another thing to look for while disassembling. I wonder if the watch left the factory that way.
    • Next is to drill the screwhole this then provides an anchor point so the bridge doesnt slip around while scribing the shape. A cork lid, a pin and a piece of gaffer tape ( 😅 ) keeps it all in place. The hole is measured from the broken part using a hand measuring gauge. Mark the hole, punch it and drill it off to size. The awkward bit is working out where the jumper should be and the detent positions.  I remember watching a youtuber a while back do this with dividers, so i dug out my old school compasses and improvised a little. This bridge only has one hole and to find the detent positions you need two points of reference, so i just worked the second point from one of the corners, hopefully its near enough. Then scribe in the jumper using the two detent positions ( wind and time set ) that were marked and a big picture of the complete spring to look at that helps to give you a feel of where the jumper should be.
    • Right now I'm making do with a similar micrometer (the one below is $45 shipped but you can find better deals) and a $20 stand. You do have to be excruciatingly careful measuring jewels, since there's no table, but if you don't have the $500 to throw around, it's a nice option.
    • As  I kid, I'd watch Godzilla stomping over buildings and cars and I'd think to myself: Tokyo is a really dangerous place to live... . Cool watch!!
    • Next one up an AS 554, looks like a bit more to this one. First job is to check thickness, most springs are somewhere between .3 and .4, this one measures .35, that matches in with the .4 spring steel i ordered. So for marking up a permanent marker comes in handy to colour up the steel to be marked later with a scriber once its dry. Bestfit provide the extra bit of info for the jumper spring that is missing.
    • Thanks again, Marc.  Super helpful. I was wondering what the hole was for, and now it makes perfect sense. With your help and the other members here, it looks like I'm good to go with my Seitz tool set. I had to order some replacement pushers, but with those, the set is complete and in good condition. Now, I need to figure out what tool to buy to measure jewels (amongst other watch-related parts). I had my eye on the JKA Feintaster micrometers, but people get crazy bidding on them for $400-600 USD. I was thinking of just a regular digital micrometer (Mitutoyo). Thoughts?  Mahalo. Frank
