HELP with snap back case
saswatch88
Hey guys i just got a cheapo swiss waltham automatic That was surprisingly running pretty accurate. I decided to take the back off just to see what kind of movement was inside andvthats it. Now the issue is when I snap the caseback back on it stops the watch! I do not hear the counterweight spinning. So it’s definitely pressing on top of the movement. I swear I literally did nothing to this watch except open it to see the movement. And FYI this has nothing to do with the gasket or the movement ring. I have tried putting it on 100 million different ways. The movement is in the exact position it was in when I opened it. I am two minutes away from throwing this damn watch in the garbage. Can anyone give me some advice or something as to why all of a sudden now when the case back is on it is pressing the top of the counter weight thus stopping the watch. This is just one of those issues that makes you scratch your head or possibly go out of your mind.
Did you get the orientation the same? Some case backs have a stem cut-out.
And what did you use to press the case back - is it possible it deformed? Finally, I presume the movement and dial are seated properly in the mid case?
we need a picture of the case back preferably both sides. Often times caseback's will help you or give you a clue of where you're supposed to be pressing the put them on. not all caseback's will go on with thumb pressure in the middle. Sometimes after pressed on the outer edge. Or as pointed out above a lot of times there's a notch it has to be where it's supposed to be corresponding to the stem. Then I have seen some caseback said a really really close to the automatic weight you can sometimes actually see the scratch marks on the back.
Sounds  like a bent or deformed case back. Do you have two nickels and a pair of vice grips laying about ?If so you could try sandwiching   the case back between two coins and giving it a gentle squeeze. Easy mind you, unless you want Thomas Jefferson stamped onto your watch. Be sure to stay clear of the rim !
Edited by yankeedog
I dont see any groova for the stem Or any markings inside of the back that indicate any rubbing of the counter weight. Are used a photo from the auction showing the orientation of the case back and I snapped the back back on in the same exact position. And it still has no effect I cannot understand this at all
The gasket on the caseback looks like it's been pinched as well as not being seated properly (left side). I wouldn't be surprised if snapping it in that way puts enough pressure on the movement ring to bind up something.
I tried it without gasket too and no dice
Rats, that was going to be my next suggestion.
Have you checked the position of the movement ring? Try to see if a little pressure on the ring stops it.
I also tried with no gasket and no ring and with gasket but no ring i tried every wich way i could
At the top of the picture, just outboard of the rotor, there looks like a fragment of something wedged between the movement and the case.  It also looks like something could be missing from the case back in the lower left quadrant. Sometimes it's had to tell from pictures.  But it's worth a look.
Took rotor off and it runs put it back on and stopped now the movement is no longer working and rotor bearings are screwed up in a fit of rage i launched it accross the room so its now in my junk bin. Never in my 8 years of experience have i ever had an issue like this come from simply removing then installing a caseback
Hi, I had this issue with a watch that I was reilluminating a couple of years back. The watch was working perfectly but when I put the movement back in the case, it refused to work. I eventually found that I had somehow fitted it back into the case were the seconds hand was touching the back of the crystal. I had either replaced the movement off kilter or pushed it back to far into the case. By replacing the backplate, you could have impacted on the rotor and moved the movement further into the case. Academic now but something to consider.
    • No matter what I did, I could not get the amplitude more than 240 deg. At least there is 0.2 beat error and minus 1-2 s/d.  So, probably not the happy end I would have hoped for, but still I think the watch turned out quite nice. You be the judge of that. Thank you everyone for your help!
    • its used to lengthen or shorten the suspension spring from the front f the clock dial, this in turn will give regulation to the clock. Try inserting a pocket watch key or even better the double ended key for the clock into the small aperture on the dial at the top and turning it, you will see the suspension block either raise or lower. If it raises the clock will run faster if it lowers the clock will run slower
    • Grateful for info regarding the nature & function of the horizontal cog and the unit it's on top of in the picture. It meshes with a vertical cog (enclosed in the unit) on the arbour which is supported at its other end by the back plate of the dial unit to which it is not quite perpendicular...
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
