No Side Shake
Nora
Hello All
I've changed the balance staff and trued the balance wheel in an Elgin 12s grade 303. The staff binds in the last 16th turn till tight of the cock screw. The wheel can be easily turned but does not spin freely. With out the staff in, the cock tightens an 8th of a turn past the binding point. The problem is that there is no side shake in the last bit. I found that when the cock has been tighten the staff will stick in the cock jewel. My first choice I feel is to shim the cock, but what type of stock should I get? Also what is the best way to trim it to shape? The thought of some type of broach to open the one end of the jewel also crossed my mind. but what type of broach? All of what I see for sale new just refers to use on metal.
Thank you in advance
On newer watches where the jewel is pressed into the mainplate it is possible to press the jewel in a bit to achieve the required endshake.
Im not familiar with the Elgin 303 but I would also check if the balance jewels have been swapped round as this can cause problems if they're not identical.
Another thing to check that the roller jewel interacts correctly with the pallet fork. If the staff is too long on the mainplate end the roller may only contact at the tip of the jewel instead of in the middle, shimming the balance cock wont help improve this.
Good luck.
Anilv
Is staff shoulder curved on this?  Dose staff get stuck to the jewel on cock side only?
If staff shoulder and jewel face are not compatible( shoulder curved and jewel face flat) , you should see excess variation in FU position, even when you do create some end shake.
How are jewels to be moved if secured in place by screws?
If pivot is bent, TG would show it as you increase the end shake.
when you replace the staff did you measure the old staff versus the new staff? then what was the actual staff number you used? Also are you aware of that Elgin staff numbers are not unique parts? In other words typically with each of their balance staffs the pivots sizes could very. So for instance for the grade 303 your staff numbers 2802 which came in four different pivots sizes.
unfortunately unlike Swiss watches where one staff is probably the right staff American pocket watch staff replacement has issues. It's why it's very important to measure all of the dimensions of the old versus new staff to avoid unpleasant surprises. That's because there are variations in sizing not just with the pivots size. Then a lot of times with modern replacement staff's rather than having four different pivots sizes they will just have a large size and allow the watchmaker to reduce the pivots to fit their watch.
Yes, and only when tightened fully. I haven't installed the hairspring  yet, nor is the fork in either.  After the balance becomes to stiff to turn freely it will come out with the balance cock.
Yes I measured them. I ordered 6 2802's to start with and sifted threw them to find a match. I was not aware that there are 4 pivot sizes. All of what I received have an OAL of .162" with a   pivot diameter of .004". So I just went with it. There was nothing for me to compare with the pivots, both ends from the original were missing. What makes them different is the shoulder dimensions.
Are you aware of any listing that shows the pivot sizes options for  each watch type? I got the staff part  number from https://pocketwatchdatabase.com/  but as you pointed out there are 4 sizes of 2802 staffs. The side note said  "See notes on Balance Staffs in Special Information Section". However that made no mention of any variations.
Pivot shoulder might partially be entering the jewel hole and stick to it, I examine the jewel under magnification for sign of damage. No need to remove the jewel, just view it from under side of the cock.
Jewel hole might be way larger in diameter than pivot, in which case you should feel excess side shake when cock is not fully tightened.
Dirty upper jewels is likeliest and most common cause.
I believe this may be true. All looked well with 10x. So I removed the cap jewel then reassembled. If the pivot jewel is seated fully it will bind. With slight movement of the balance wheel to  dislodge the jewel it will spin freely again. However it will bind again under the weight of a 2 mm pegwood.
You might furthure narrow down the fault  by switching the upper and lower jewels around, then if staff still stick to the cock side, the cock itself might be bent, if it sticks to other side the fault is with the jewel. Bent pivot is very common. Both jewels should look the same, oil cups shouldn't face the pivots. Its either by elimination or visually spotting a fault.
1 hour ago, HectorLooi said:
Looks like it's time for you to get a jewel hole gauge, a watchmaker's lathe, cutters, files, burnishers and start polishing down your pivots.
I'm hoping for next year. I have more learning to do before I make that plunge financially.
as a reminder this is an American pocket watch swapping the jewels around doesn't always work because they're not always the same size. Then bent pivot shouldn't be an issue for a new balance staff hopefully.
pocket watch database is a good source for watch parts. If it's an Elgin watch you know the grade number this is another place to look although it does have a minor issue.
http://www.elginwatchparts.com/Script_Find_Grade.php
the minor issue is there's a reference to the notes found at the bottom of the page. Like for instance those balance hole jewels that somebody claimed were identical don't appear to be identical depending upon your serial number. Then there's a reference the balance staffs but that refers you to another section that doesn't exist on this page.
if you're going to work on American pocket watches there is a definite must-have reference book that almost no one has ever heard of which is Swartchild & Co Chart Book for American Balance Staffs. There is also a second book that has the jewels listed. I miss snip out the section on the balance staffs for you.
https://www.ebay.com/itm/Swartchild-Co-Chart-Book-for-American-Balance-Staffs-reprint/162769575312?hash=item25e5d29d90:g:zhoAAOSw1HtfGEpv
then I'm attaching another image another way to tell if your staff is sized correctly for the whole although you do need to do this test before you've attached the balance wheel it's a little hard with the balance wheel on.
  • Thanks 2
Is staff replaced with the right one? Are jewels, pivots and the cock perfect?  A host of possible causes are to be checked in the hopes of finding the fault.
Regards
Thank you all for the useful  information! I have found the definite problem that is causing it to bind.  The pivot is indeed to large for the hole in the jewel. I took one of the other staffs with the same sized pivots and tried putting it in the hole with the balance cock flipped over. It comes nowhere near the shoulder, but binds up on the pivot itself The staffs that I've got are generic  from an eBay store. I don't mind the outcome. I have learned a lot about what more I need to learn /get to make it happen. I'll come back to it again as a future project.
bingo. working on an Hampden a few weeks ago shaking my head in utter confusion staring at my bench....then found out exactly what you said. there's a guy in Ohio I get my stuff from says he has all the old Dueber-Hampden stuff from parts left over after the move to mother russia.  staffs are all over the place. in the beginning he had had the same problem. had to measure and  fit up staff to cap and pinion jewels, both top and bottom. got passed that, worked like butter. gave me a helluva headache tho.
ain't it fun?! was at the same point you are just days ago. John has some great references for keeping at hand. that diagram he shared is exactly part of the info that helped me when I was stumped except I got it out of a copy of the Chicago School of Watchmaking. I learned this from an old retired repairman when I bought his old staking set. Warning! as I was told, don't attempt to read it. there is just to much to try and soak in, the book is huge. instead he said, dig into your watches, and reference it as you go along. Otherwise he said, "you'll go nuts!" he was right. it works for me. enjoy.
Edited by MechanicMike
wrong name!
    • I think we are about there, if there were still lots out there then the cost of a watch from 5 years ago would be around the same as it is now (allowing for inflation). Given that the price has gone up several times over we can only assume that supply cannot keep up with demand so we must be at or past peak supply, especially if the trend continues. I see even places like Australia, Ukraine and even South America are selling watches on eBay, picking over their stocks, mixed in with fakes and Frankenwatches etc.
    • I understand the demand bit, the generation below me 30ish are too technology engrossed to own a mechanical watch and they just dont like old stuff. I also consider myself at the getting on age of 57 to be a rare find of someone that likes old stuff, i did buy an almost 100 year old book yesterday titled " The New Modern Home " printed 1929.  Cost me a quid. What i was trying to work out is if we have reached a volume peak of watches being discovered hidden in the back of drawers.  Those watches that were hung onto until they entered the hands of the non sentimental generation.
    • Even for myself who only started getting into watch repair/servicing during COVID I have seen a huge jump in watch prices - we have a 404 channel on this forum. When I started you could relatively easily find a watch on eBay to restore and put onto the channel, however this is now almost impossible and the only feasible solution is to buy a job lot with an average price <4.04. Even watches sold for parts/spares are 3 or four times the price of only a few years ago. Why - Either Demand must have increased in order to push up the price, or supply is reduced. I think it is a little of both, I think that most watches in the UK/US may have been picked over, which agrees with most of what @Neverenoughwatches says so supply of all kinds of vintage watches, including tat is dwindling. As a double whammy I think that more people are wanting watches, either to work on, or as a way to differentiate themselves from the Apple Watch and FitBit crowd. The upshot is that half decent watches that require restoration are now $500 instead of $100 and cheaper watches (Seiko 5 etc) are now $50 instead of $10, and even Mumbai Specials and garbage are now pushing $50 each. When - how long will this last, I think that most of the people who are returning to mechanical watches are those that have previously experienced life without them and want to return to something with a bit of personality that doesn't buzz every 10 seconds on your wrist and tell you how many steps you have done today. i.e. the 30-40+ generation. My son who is 17 has several mechanical watches but only wears one on a special occasion and is obviously only aware of them at all in part due to my hobby. I asked him the other day how many of his friends wear a watch and he told me that some use a smart watch but most just use their phones. So as I see it, demand will start to fall once the sub-thirty crowd start becoming the majority and/or the older amongst us stop buying watches and switch our attention to mobility scooters and trying to remember our bank password. Price - I think this is here to stay, even if demand does start to drop as the older generation becomes to decrepit and stops buying and the younger generation isn't interested in buying, supply will become progressively less as time goes on as more vintage watches become lost or broken beyond repair. I think the prices will plateau at some point as an equilibrium is reached as reduced demand is balanced with reduced supply, i.e. less and less people buying less and less watches. Sorry for the long ramble!
    • Hi. Use a PVA based glue, gorilla glue it dries transparent then do as advised by Old Hippy, smoothe down using very fine  0000 wire wool and either French polish or beeswax for a finish.
    • Hello and welcome to the forum.    Enjoy
