Quartz movement run slow
14 minutes ago, Nucejoe said:
@rodabod  Aprox 2 minutes/ hr slow.
I'd watch the seconds hand for a few minutes and see if you observe it ever stuttering.
Of course, the easy option is if you have a quartz measurement tool, but most of us don't own one.
There is always the possibility of a faulty Block  but they either work or dont work,  Unless you have an analyser or some method of testing the module ie current consumption its difficult, High consumption is usually a dirty mech drawing more current to over come the dirt.
2 min per day is indicative of a sluggish train,  Whats the calibre number
Thank you watchweasol, I am not yet sure if I should crack the back open. must have a quartz eta inside. Will ask you for datasheet if it gets to clean and lube.
The watch is a friend's who didn't know, I am quartz ignorant.
Hi Nucejoe  A quartz watch is no different than a mechanical one  apart from the fact the Battery provides the voltage/current the block interprets this, The crystal vibrates around 32,768 times a second the block divides this down to normaly one pulse a second which is output to the coil which causes the step motor to pulse once, this turns the gear train and then the hands.  Some watches pulse once every 4 secs  or 6 secs depending on the make.  As the current drawn is in micro amps it doesnt take much to affect the module ie dirt and old oil or even the wrong oil should be  9024 and 9027.  The attachment explains both the mechanical and the quartz.      regards
Witschi Training Course.pdf
  • Thanks 2
Thank you WW,  the minute hand completes each forward move by one second on dial markings with each pulse.
But, it's dropping seconds somewhere.... When I say "stuttering", what I basically mean is, is the motion irregular in any way?
Hi    when the block is calculating the pulses it uses a thing called inhibition and if the checksum is not right it either adds or drops a pulse to automaticaly correct the calculated error ,  so there is the remote possibility the block circuit is faulty in its calculations. But these circuits either work or dont work they are that reliable but one should not discount the possibility.  If it were me I would clean and oil the movement and re run any tests using the analyser, Not having an analyser use a analogue meter and watch the coil pulses for a regular beat or just run the watch and observe the timing.
    • I have removed the stem and open the case. The Movement can't drop out but it can be rotate Anyone has idea THANK YOU
    • Not a family member, and yes, it no way near as good, as some information got lost from original site and some information got incorrectly copied. The original site is available as iOS app here: https://apps.apple.com/fi/app/ranfft-watch-movements-archive/id6502008939
    • Outstanding, Marc! Your information is really helpful and clears this up, especially given that yours were purchased as sets. Thanks, man. So, it appears I jumped the gun on this one, but I am relieved. I will say, though, that all of my reamers and concave pushers are number-stamped and appear to be of better quality.  Also, the bayonets on my pushers are actually the same color as the steel.  The next thing to do is restore the heads of these pushers with some polishing paper.  Alex at the Watch Repair channel has a nice little video on this.   I appreciate your help! Frank
    • Just installed it on my iPhone (my only iOS device) and it appears to be intact and functional. I may have to go out and buy myself an ipad just for this app.
    • I have two Seitz sets, one ancient (with the 3mm anvils) and one just old (with 4mm anvils) plus a collection of spare pushers of assorted vintage. Not one of them is marked with it's size. Something which I have found very irritating when I have been using the tool and not returning pushers to their correct place in the tray every time as it means that I have to get the calipers out and measure them. These were bought as sets and collectively I have over 100 pushers so it would seem highly unlikely (if not inconceivable) that they are all cheap knock offs, especially as they are old enough to pre-date the prevalence of the Chinese knock off industry (at least as applied to watch making tools). I therefore believe them to be original Seitz parts. And there is no numbering. The shape of the bottom of the pump pushers is the same as your photo. The only thing that may not be the same is that the slotted insert (looks like a screw but is in fact a bayonet) should be brass. Yours looks the same colour as the steel but that could just be the lighting.
