So I'm dealling with an old ETA 2783 (In case some of you did not fiddle with this particular model, it's basically a 21600 version of 2824) . Normally I can get a 280 amplitude with this model but this time I have a lot of trouble. What I get now is 240~250 and +4s/day Dial Down/Up, 200 -15s/day Crown Down/Up. I've check the endshakes and the hairspring seems fine to me. Anything else should I look for. What's your intuition if you face such problem? Thank you guys!
Have you checked pallet jewels under high magnifiction?  they get scrstched up over time specially if run with dried up oil.
Fork pivots are not to be oiled.
Expand
Your amplitude is lower in all positions, so the impulse you get is not as strong.
so you mean the impulse face might be scratched?Let me check it later. The amplitude is indeed lower than I expected. I took a long time to make the train runs freely but the amplitude is still low. BTW I'm using 9415 and 9010
Expand
Thats the grease of choice alright. Surely you know considerable amount of energy goes to waste in the escapement. What kind of beat error are you getting?
within 0.5 at all position
If the train is free, balance pivots and hairspring in good condition, and still low amplitude, I check the escapement. First of all absolutely peg the hole jewels for the fork, and clean the fork slot in clean pithwood, make sure the roller jewel is spotless. If all that is in order, you may need to reduce the lock if possible. I actually do on probably 30% or more of the watches I work on.
Expand
Let me check that. The lock is something I suspect. But I have not pallet warmer to alter the lock, too bad. And I think the stone is really hit the very end of the fork so there's very little I can do with it.
You didn't give us the background story did you service this watch? Did you change the mainspring? Then if you did service It what was it doing before you serviced it?
I did service it. The mainspring remains the same as the original. But I guess it's strong enough to power the movement. Before I service it it was a no runner
Expand
1153397792__20200612175324.thumb.jpg.ff3f71296c789a7ca12bbae01979ff91.jpg970504750__202006121753241.thumb.jpg.7b9531e484ad613afd897d951ba6f61c.jpg7439136__202006121753242.thumb.jpg.2697ff5a75e250f1850b4ba33c78a54c.jpg21850996__202006121753243.thumb.jpg.1fa9037f560226e95471e7ac395c9a67.jpg
There you go
Try checking the amount of play the hairspring has between the curb pin and boot in dial up and down, then check if it's the same in crown up and down. I suspect not. It might be the hairspring is ever so slightly out of true, therefore the hairspring has no movement off the curb pin in that position, or too much. I couldn't tell from your reading if it was gaining or losing in vertical position
Expand
losing
There you go
Expand
Sorry for my abscence, I lost some graphic aspects of connection to the site plus couldn't post for couple of hours.
I can't see anything wrong with pallets face. perhaps heavy lock on escape teeth, will you show pics before attack , also Jons point for amplitude drop in FU position.  have you checked pivot on cock side?
Expand
I've send all pivot holes pics just now. They seems good to me. The update is I found another pallet fork with less lock and change the 9415 with 9010. Now I'm getting 250~260 dial up but 210 crown up
Companies like ETA are interesting they have technical information for servicing the watch. But  some of their watches they also had  the manufacturing information sheet.  I've attaching an image from the 2836-2 . A little newer than your watch but it give you an idea about specifications. Notice comes in four separate grades of quality  important to remember when you're doing timing..
What I wanted you notice was  let's compare your hideously bad timing and amplitudes to this? First off the watch companies  almost never worry about  what the amplitude is  except at the end of 24 hours. Then  your horrible  +4 to -15 Timing Variation Really isn't that horrible  if you look at this.. Unless of course this is a chronometer grade watch then you write totally sucks.
The positional variation doesn’t sound unreasonable taking into consideration the slightly low amplitude.
I usually cringe when people immediately suggest checking mainsprings/barrels, but if everything is clean and looks in order, did you check how many barrel turns you were getting before slippage?
Expand
No, I did not. But just by turning that mainspring it feels rigid enough for me. At least I think it would be the first priority. Just an intuition
Yes, the amount of torque you can feel coming back through the crown is usually a good indicator if you have a feel for what is typical, for a given crown size.
If you have spares, the I would try experimenting by substituting parts. I have had issues with higher beat-rate ETAs where they have formed a metallic sludge on the escape wheel teeth.
Expand
Yes I did change some parts but have no significant improve. I did get some improvement of amplitude by changing the escape wheel and pallets. But the prositional error is still high.
Expand
As were discussing positional errors  you probably should adopt a better timing policy.. Like time of the watch In six positions.. It really helps for diagnostic purposes To see what it's doing and you can look for actual balance positional error problems. Not that you should have any on a modern balance wheel but she never know.
Reading through the answers above the escapement lubrication did you go minimalistic or heavy on that? The reason I ask is if you have too much of the lubrication it actually causes a decrease in amplitude..
Then the wording of the mainspring remains the same? In other words you using the old mainspring which is fine if did you take it out and clean it?
Expand
I think the lubrication should not be a problem. I try different amount and different types of oil. The amplitude is still stuck at 240~260. As for the timekeeping,  any vertical position will lose 10~15s/day so that's a problem. I dont care if the amplitude is low but the timekeeping should be better at least the variance between vertical and parallel should be minimized. As for the MS, it's been clean and oil. It should not be a problem. I'm thinking about the locking, I think it is a little bit too deep but I have no tools to adjust it
If you’ve swapped all of the escapement components out and still don’t achieve good amplitude then I would start to suspect either a mismatched escapement component, or lack of torque arriving at the end of the wheel train.  It’s a shame there isn’t a more simple way to measure this.... I have been thinking about making some sort of strain gauge, but it would potentially be a lot of work.
    • I've been on a ESA 9154 kick lately with this being the latest. A funkalicious 1970's Elgin Electronic with a brown and orange earth toned dial in a big old hunk of steel. Just like the last one this one runs from about -2 to +2 in 5 positions as it seems to be easy to dial these 9154's in.
    • I wonder what the theoretical size limit is for both a quartz and mechanical movement?
    • I'm currently working on a Citizen 4520 movement. This has to be the smallest and weirdest quartz movement I've ever worked on. Firstly, it's small. Really small. Here's a picture of it next to a LR44 battery for comparison.  And unlike conventional quartz movements, the construction of this movement is really weird. The moment I took off the top plate, the rotor and 1st wheel are exposed. The PCB is right on the bottom plate. There are no dial side components and cover plates. Everything goes in from the rear. Not sure if I'm able to fix this watch. The old battery leaked and there are battery juice crystals everywhere. And there is a 1 uA constant leakage current, which will drain the tiny battery in no time. But at least there's still a pulse and the rotor twitches.
    • Afraid this is where it could get down to old school adjustment and observation. There are pallet setting tools..but the calibrated ones aren't cheap. The observation holes in the plate will allow you to see if you have one or both stones hanging up/ not engaging on a tooth, That would ofcourse require you to disassemble, heat/move the jewel in/out as required..by eyesight and experience. It's truly trial and error until you get close enough that you could make small adjustments with the banking pins until they drop to the lock freely. You can use a Potence tool to help hold the rok in place during reassmbly. Here's a pic of one...made with a piece of old 18s mainspring You just fold over a roughly 2 inch piece, then file a slot on the end that engages the pallet fork arbor
    • It least you know what to order.
