Help determining part name?
Hello, I am working on an AS 1320 (Bulova 10BRC, 9AS) automatic movement and have found it to be missing a part for which I cannot find a name. I have looked at the 10 BRC automatic assembly parts list and the parts list for the movement itself and still cannot locate it. Here is a photo with the missing part outlined in red.
It is a spring-like device that prevents the automatic assembly's third winding wheel from engaging the ratchet wheel when the mainspring is fully wound. If anyone could tell me the name of this part so I could order a few replacement parts, I'd really appreciate it!
25 minutes ago, oldhippy said:
Can you post the link to the parts list or up load the list please.
I rember the part name list.    haveing a hard time finding it !    i'll keep looking.     vin
Hello, I used the Bulova Self-Winding Watches booklet (pg 18) and the '52 Catalog of Interchangeable Parts (pg. 79) to attempt to identify as many parts as I could.
15 minutes ago, Walsey said:
I don't believe that is the part but thank you.
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
    • I overhauled a ladies Rolex and noticed erratic performance so I stripped in down again and did fault finding. This is what I saw. The lower jewel (the one in the plate) is cracked and the hole is too big. Before discovering this, I stripped down and re-cleaned the main-plate (and parts) by hand with a fine natural fiber brush. I somehow missed the fault the first time and cannot understand how it was still running. Perhaps re-cleaning it dislodged some pieces of the jewel widening the hole? I don't know. Now I need to replace the jewel but don't have a Seitz tool. The Rolex part is 2130-0913 and the top and bottom are the same. The part comes complete in brass setting with KIF elastor spring and cap jewel. Note: I have never replaced a jewel. I do have a good vintage stacking set that I've used quite a bit.  Can I replace using a stacking set? Any suggestions would be greatly appreciated.
