Mindboggling
I find it mind boggling that people will pay this sort of money for a 7750. In the same listing you have the same exact movement for a fraction of the price. People have no clue what inside of a watch these days. 9fee507362a03afa65008df63b3a9d6a.jpg
Sent from my SM-G950U using Tapatalk
That is only an asking price, it's common to see exaggeratedly high ones for any kind of item. If you want the see the actual going price search for completed sales.
Anyway to me paying more than $1,000 for a 7750 watch just because is made by a sub-brand of the other one that makes mature men drool is craziness already. I have for sale an nice Swiss, brand new 7750 from a popular but not-so-lucky maker and it will be hard to less for $800.
Maybe I misunderstand your post. "Normal people" don't by a watch primarily for its movement. What matters is the brand and what it looks like. You can buy a new Breitling for $4000 housing an ETA 2824-2 (albeit decorated and chronometer).
Breitling, like IWC and others that I don't care to mention here is another  notorious "overcharger" which bases sales on active lifestyle sponsorships and advertising - they deliver little innovation beside casemaking. Most people would not even care to know that for the same money you can buy a bespoken automatic watch, designed and produced  in house during this decade.
What I find interesting is on the other end of the price scale. Five dollar plastic quartz watches in cases that somebody spent a couple hundred dollars for because they like the way it looked or the like the brand name and they don't care because nobody bothered to tell them that their watch inside is worth five dollars. After all If your A watch salesman why would you tell someone what's inside the watch your there to make money.
Exactly. Maybe thats more the point I was trying to make. I dont think people understand the differences in terms of value that goes inside the watch they are wearing. The history on the whole watch movement industry from the 50s to now with the consolidation is quite a story.
Id say once you get past $1000 unless the watch has gold or diamonds youve pretty much exceeded the value of the best 7750s in my opinion.
The whole question of price is based on brand names, the bigger the brand the greater the price. The same can be said at the other end of the scale  the greater profit is a cheap movement in a flash big brand case. The average watch buyer knows nothing about the mechanics of the watch only that it carries an in you face  big brand and by that has street cred. But as Old Hippy says its their money and if they want to spend it on a flash watch with no guts that's their problem. They only get disapointed when it stops and Mr watchmaker  tells them it cant be fixed and the answer then is I paid £££££s for that watch. Up till then is just bling on the wrist.
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
