I thought this would be relaxing.
Tom32
Hi all,
I'm a frontline emergency services worker in London and started watching Mark's video's on YouTube as a form of relaxation and destressing after work.  I eventually convinced myself I could build my own watch. So I ordered an automatic movement, watch case, dial, hands and strap.
I broke the first movement, the dial doesn't fit the case, and I'm now waiting for delivery of a dial spacer I didn't know I needed when I started this project in January. So if nothing else I've started to examine my understanding of patience.
I've had a great time reading around the subject of horology and have started getting the materials together for my second watch. Learning to maintain them will be the long term goal. In the meantime, I'll be asking for your help to put them together.
Please bear with any obvious questions and thank you in advance for any guidance offered.
All the best,
Tom
1 hour ago, watchweasol said:
Hello and welcome Tom to the forum,  At least you can put it down and have a pint and start again in a better light, as far as that goes ther is no pressure.  two attachments that might be of use to you.    Cheers
TZIllustratedGlossary.pdf 4.2 MB · 1 download TimeZone Watch School Home.html 8 kB · 1 download
Thank you for these attachments and encouragement, they will prove hugely useful I'm sure!
12 minutes ago, Nucejoe said:
Welcome to the forum. You didn't break the whole movement, I hope! A true watch maker never throws any broken part away, at worst you have bunch of spare parts.
Thank you. Hopefully not, I hope to fix it one day, or at least you it for parts/practice as you say.
I'm pretty sure we have all broken a few over the years, its all part of the learning process.
I seem to still be capable of breaking the occasional victim in "new and interesting ways" from time to time.
The skill lies in fixing more than you break, and "unbreaking" the ones you broke while trying to fix them.:P
Hairsprings are a particular favourite on the "ooops what happened there part" of this journey, followed by balance pivots.
Unless you ran it over with a tank, I'm pretty sure your broken movement can be fixed. What exactly went wrong?
Thanks Andy. I'm all out of tanks, but sadly that does accurately describe my handling of the first movement.
While the hour/minute/seconds hands were keeping time, the date wouldn't change with the passage of 24 hours. When the stem is in position two to change the date manually, the stem just spins freely without changing the date.
I may have also upset the mechanics between using the stem to manually change the hour/minute hands as when the stem is in position one, it is making a loud clinking sound when turned that I do not hear on the second Miyota 8215 movement I am now using. It is also not moving smoothly and eventually crunches to a stop when turned.
The first few minutes might be where your issue lies. I'm not advocating stripping the movement down unless you are comfortable doing that and have the tools, but it will give you some idea of what is involved.
Whatever the issue is, the keyless work is likely to be what has popped out of alignment.
EDIT: If you do attempt to strip it down, be aware that there are a couple of springs that like to become airborne, when you remove the three screws in that top plate. Don't say i didn't warn you. :P
Edited by AndyHull
Welcome Tom
Nice introduction.
As you're finding out, Mark's experience makes it look straight forward. Don't give up though, it's a rewarding hobby once you've cracked it
Keep safe.
Sent from my moto g(6) play using Tapatalk
45 minutes ago, oldhippy said:
Thank you for your introduction and welcome to this friendly forum.
Stay safe Tom.
Thank you, I look forward to increasing my knowledge and pushing my skillset.
Exactly that, I also blame the music for assuming I'd be in some kind of zen state when working away.
Thank you for the post.
Thank you for the video, that will prove invaluable. Maybe I could do all my work in a well lit one man tent to increase the chances of finding springs that like to sprung!
The current plan is to finish the automatic watch for everyday wearing, and the quartz watch I want to use at work. As soon as that's done, I "look forward" to stripping down the mishandled movement.
It also just occurred to me that I read your introduction thread before signing up. The 404 club is an inspiring collection, being able to service and refurbish watches half as well as some of yours would be a huge achievement.
The yoke of the keyless works is very easy to break. I should know, I did it to my first movement ... TWICE! The nice thing about using readily-available movements is that parts are easy to find and relatively affordable. Take your broken movement apart, taking LOTS of pictures in the process so you can get it back together. Inspect everything closely and see if you can find where issues might be. Even if you don't get it running you will develop some good part handling and examination skills.
Oh, and welcome to the forum.
That's reassuring to read, thank you. Pictures will no doubt be key, not only for me to put it back together, but also for when I come here to ask why my square peg won't fit a round hole.
    • I've been contemplating getting one of these for some time now, after working on a few spring loaded centre seconds pinion movements. It's not an absolutely necessary tool to have, hence the procrastination.  Then it hit me, all I need is a flat base with a screw in it. So I scrounged around for something suitable and ended up with this. This is some rubber thingy that is  supposed to stop furniture with casters from moving around. In fact, any flat material with sufficient thickness to hold the screw in the centre would do.
    • I think your axes are mislabelled here. They need switching around.
    • @clockboy Thank you for the response.
    • @Knebo Thank you for the detailed response and reminding me. I went back and introduced myself. That's really good information, for 15xx it should be similar. Will dig deeper into that.   Yes I mean that. Attaching some pictures. New to shooting through a loupe so pardon the quality. I don't quite get the strength point, could you elaborate? Seeing the punch used for the job, it should limit the highest point of the metal being pushed, Maybe a worn out punch?       I haven't checked the axle will do that, but thee watchmaker told me that the 9'o clock side has been over-polished and the caseback is sinking on that side which is causing the issue. Armed with this knowledge, I will investigate both. The Picture would certainly suggest that plus the Intense pitting (wrist perfuming habit of my family) might be contributing to how the caseback fits.      Thank you again, I have made a checklist and will be investigating all the points you mentioned.   Rolex told me that they will replace the dial and bracelet so I didn't go that route. Its an independent watchmaker, and a very well reputed one in online and offline collector circles. I have seen his work and got work done from him before, this is the first time something like this is coming up. Maybe he is getting lazy in sourcing good parts. lol.
