Hey guys. I'm trying to clean a very dirty train wheel bridge. But this particular bridge's cap jewels are sealed. I can't not remove the cap jewel and clean it throughout. Do you have any experience to deal with it?
BTW, I don't use machine to clean watch parts. Usually I use No.120 Solvent oil to soak and brush parts and then rinse with IPA.
758567482__20200310143846.thumb.jpg.0836a477e1e9a91422029208ab22b589.jpg191923108__202003101438461.thumb.jpg.9a2d86ed0b10d1bde0a169264994c7f1.jpg63930599__202003101438462.thumb.jpg.7fdbdee4660addbbbd855fabe2f2a931.jpg252163939__202003101438463.thumb.jpg.8f0c3cd0e4abc8dffe62dc8be1ed4e55.jpg1039200415__202003101438464.thumb.jpg.b6c436ce6ccbd1a07114c34e2c73977e.jpg
Edited by EatPeach
Hi there that type of jewel setting has 3 holes around the outside edge for cleaning solutions to penetrate ,it looks like a shock spring goes in there but it doesn't  you can soak and do as you say with ipa ,give plenty of time to dry .You can also gently clean hole with pegwood but don't break the end off or you will have to press the setting out ,which is another way of cleaning it if you have a jeweling press . A good soak and a peg then rinsed and oiled it should be good as gold .Hope this helps
Edited by Graziano
1 minute ago, Graziano said:
Hi there that type of jewel setting has 3 holes around the outside edge for cleaning solutions to penetrate . you can soak and do as you say with ipa .You can also gently clean hole with pegwood but don't break the end off or you will have to press the setting out ,which is another way of cleaning it if you have a jeweling press . A good soak and a peg then rinsed and oiled it should be good as gold .Hope this helps
Yes I did soak it several times but the dirt seems a little bit stubborn.
Try soaking in naphtha or lighter fluid overnight with the occasional brushing and swoosh around ,a cheap ultrasonic machine is ok
Edited by Graziano
OK. Let me try it. BTW is ultrasonic cleaner working better on these jewel settings?
Ultrasonic is good for cleaning stubborn dirt and congealed oil of all the watch parts. Put the parts into small jar half filled with lighter fluid , don't put watch parts in water ,sit jar into ultrasonic cleaner which will have some water in it  .A Couple of 3 min runs should remove the dirt
Edited by Graziano
I think this is what is known as a rubbed jewel. If so you can remove the jewel using a jeweling press and once the jewel has been cleaned you can then rub the jewel back in using a rub in tool. Mark has a vid showing the replacement of a damaged rubbed in jewel see below. HOWEVER I would not (if it was me) attempt without the correct tools. A really good soak and if you have not got a ultrasonic cleaner then use a blower to clear the dirt.
As @Graziano said there are 3 rectangular holes in the edge of the mounting to facilitate the flow of cleaning solution. The trouble is that when the oil you're trying to shift is very congealed and you can't get a brush or peg wood in to dislodge it, simply soaking won't work unless you're prepared to do so for a very long time (try weeks!!).
What you could try though is forcing cleaning solvent through the setting using a syringe of the type you get for re-filling inkjet cartridges after a good soak to soften the gunk. Place the tip of the needle into the hole jewel so that the solvent flushes through the setting, taking the gloop with it.
Hey guys. Thank you for you advice. But a closer inspection found out one of the jewel is cracked. I'm going to ditch this bridge and replace a new one with normal jewel setting.
Usually, but not always, train wheels that are used with cap jewels will not have a pivot with a shoulder, they will look more like balance pivots. If you want to replace with a normal hole jewel you need to verify that the pivot will work; if it doesn't have a square shoulder it won't.
2 hours ago, clockboy said:
As the jewel is cracked you might as well try and repair/replace. A good learning piece.
Indeed but I dont have the jeweing machine.
This is an ETA 2763 Movement, I've seen the normal jewel setting bridge on other ETA 2763/2752 so I just find another ETA 2763/2752 train wheel bridge with normal hole jewel it should works.
  • Similar Content
    • Since I've learned lots here I thought I'd share a tip I picked up elsewhere and put to the test... For that 6105/6309 bezel lume pip look I've punched a clear plastic bottle of water, sanded it for the frost effect, removed the (smaller) pip from a standard/cheap replacement bezel, drilled it out to 2.5mm and fitted it using a smaller punch - fresh lume to hold into place.  Pressing into place is a bit awkward but you soon get the hang of it, and the end result is pretty decent I'd say... The worst part probably being the drilling rather than the pip!
    • Ive asked this at a Seiko forum but I know there's plenty of experience here too...   As I have it the recently discovered servicing technique on these is that you stuff the crown full of gaskets and work it until the recessed washer pops, remove the washer, switch the gasket out, dish the washer and push it back into place, levelling out the washer in the process? First attempt did not go to plan... I tried using a plastic pusher to manipulate the gaskets in the crown... Wasn't strong enough and I was struggling to even get the gaskets in up until it broke.   Rethink consists of making/using actual tools: I don't have a staking set, so I've got the old man fashioning a metal pusher, essentially a 2.45mm OD tube with 1.6mm ID with a 6mm press the other end. Also got him on a dishing block/conical stake (sorry I'm terrible with terms) and a holder for the crown while I'm working on it...   I figure that's enough to do the process described above? Push with the metal pusher, dish the washer with the conical stake, press back in with wider flat press (drilled centre so it doesn't catch on the tap).    Plan is to stuff, press by hand and repeat? If that doesn't work by hand I've a drill press I could attach the pusher to for a little more leverage if needed. (Obviously I don't want to go too mad with that, and hopefully can avoid it altogether...)   Sounds like a plan? I'd welcome any advice here, since I really don't want to wreck a crown. Having replaced all the other seals though id really like to sort these too. I welcome any input/advice from those who have been there and done it... Thanks!
    • Hello and welcome to the forum.  Enjoy
    • You need to be more careful modifying the dial area. How does the bezel/lens fit on the front?
    • Recently inherited a box of my Grandfathers watches, nothing valuable, but some cool and some unique items.  Seiko SQ, my aunt went to Hong Kong in the 80's I believe and picked one up for my Dad and Grandpa. Below are picture, I believe its a 1987 5Y22-8A08. Put a new battery in it and it fired right up! Its probably been a drawer for 20+ years. Looks like he only wore it a few times.   Citizen Quartz 46-9181 with a seven jewel 7961B movement. It had what looked like some moisture damage, and a corroded battery. Swapped it with a 371 but it would only vibrate the second hand. Tried trouble shooting while in the case but eventually ended up pulling the movement out and cleaning with some naphtha and blowing it out and running it on the demagnetizer for a while to free up the movement before cleaning the band and case lightly oiling and reassembling everything. Now its back up and running. Based on the adjustment of the band I believe my Grandmother actually wore this watch, and I made the mistake of telling my wife that. Now its her watch! The most interesting so far is a 72-73 Benrus.  I tried putting a battery in it, but no joy. Ran it on my little tester, no signal from the coil, tried to spin it up. Just the slightest flicker of the second hand. Put some naphtha where I could reach, and tried again to spin it up. Nope. This watch is interesting in that it does not look like the back comes off, there is a window you unscrew to access the battery, a huge SR44. Ordered a crystal puller and will begin disassembly next week.  I was able to find a little bit about this watch though a google image search; BENRUS H010 TECHNIQUARTZ 1972 1st US made Quartz made by Benrus. Using a custom E-block with the step Motor, a power switch and a Moto Chip driven by MotoQ at 32KHz, on modified ETA mechanical movement. https://www.crazywatches.pl/benrus-h010-techniquartz-1972
