Bet I'm not the first
JJM
I can happily announce the crystal is out! :unsure:
I shouldn't think I'll be the last to adopt this unorthodox approach, the crystal was damaged prior to this violation of horological etiquette. Yes I did cut myself & no, on reflection, I concede it wasn't a very good idea. :Bravo:IMG_20200309_154136.thumb.jpg.b2f01b9d34f3d9c1090b095f61a4f2d3.jpg
  • Confused 1
-_-
6 hours ago, AndyHull said:
what kind of a barbarian are you sir?! :wacko:
Fair point! ...... Well I saw on a Ulysse Nardin video a operative enamelling dials with what appeared to be a pizza oven.... So I just thought...... Its Horological/Liberty Hall here.
I'm wondering if I use a smaller hammer I could fit the replacement crystal utilising a similar methodology .....  I guess its more a gradually increase of pressure as against a short sharp shock..... Using weights perhaps...... Or my foot?
This all started by me needing a battery replaced & now look!
  • Haha 2
Have you tried a hydraulic press ?:chainsaw:
Image result for hydraulic press pictures
Edited by Graziano
Oddly enough I did have half a thought of rigging something up using a bottle jack.... I really should get a purpose made unit, maybe drop £10 on Ali express & see what happens... Cash is slim this month though
On 3/10/2020 at 10:49 AM, watchweasol said:
Hi  Iv'e got it the toaster is to warm the bezel (expand) and with medium pressure from the hammer and socket, a perfect fit:D
No bezel on this one..... Mind you, I could retrofit one utilising heat & some strategic percucussive techniques...Great idea....! I'll whip the 'Pot' bezel off my Daytona of Eastern origin & mock it up for sizing :P
Well we seem to have progress!
I will take this as a win
Its in the same position as the original
There it is, looking awful covered in finger prints .... But its in, in level & not broken
As I didn't replace the crystal gasket I think it would be unfair to expect it to be watertight.
The technical details: Original glass Ø35.87mm the replacement Ø36.46mm. I'm not too sure how
accurate these chinese digital verniers are, (£7.00 worth ;))  As at the time of ordering
I didn't have any suitable measuring devices, I did the sensible thing & looked online, took a
strangers word for it, what could go wrong ? ...... The maths says the replacement crystal is .59mm oversize
but I am living proof that "You can make anything fit if you have a big enough hammer" .....
Conclusion: I think I've been mighty fortunate, however I have also demonstrated that with a kiss from lady
luck & a modicom of digital dexterity this watch fanangling is a breeze. :Bravo:
Edited by JJM
Spelling as usual
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
