Hi guys and gals,In 1974 whilst visiting Italy my dad bought a new certina ds ph200 dive watch. Well he never had it serviced and wore it every day at home, work you name it he was wearing it for 46 years. I finally convinced him to let me have a look at his watch. It was gaining about a minute a day. So I placed it on the timing machine and nearly fell of the chair. There was a beat error of   . 1 and the amplitude was 215 degrees and gaining 153 seconds a day. But the screen had 2 close lines very straight and no snow to be seen indicating that it just needs a service. But when I opened the case back I was meet with the white chewing gum substance that looked like the original movement spacer which decayed over the years. I thought I would share this with you. Dad payed 24 dollars for it in 1974 brand new. Looks like I'll be working into the night.
Very odd to have a plastic liquefy in that manner! :wacko:Typically, plastic gets harder and brittle over time, especially when exposed to the oxygen in air. I have only ever seen plastic liquefy like that when exposed to certain solvents, even then, only certain types of plastic. I suppose it's possible someone used an adhesive of some sort to immobilize the movement in a half assed attempt to replace a lost or missing spacer prior to your fathers ownership.
Adjusted for inflation, your fathers watch cost him $131.43 in today's money.
My dad bought this watch brand new in 1974 . I have read somewhere some time ago and I have seen pictures of a whitish looking movement spacer made of some type of rubber . But my research has come up empty handed . You may well be correct it makes me angry some of the things people do to get a couple of bucks ,anyway it's a mess .The watch is running ok ,I will get to it soon and maybe post the final results when Im done . This watch is super rare as they where only made between 1969 and 1975 . collectors are paying around 2000 usd for one in alright condition .Check Out this link https://www.ebay.co.uk/itm/Certina-DS-2-PH200M-25-651-Vintage-Automatic-mit-originaler-Box-aus-den-70ern/264505058009?hash=item3d95bae2d9:g:sQYAAOSwkfRdrHg2 and thank you for your input FLwatchguy73,  looks like some one put crap dads watch187a6b7129c76baad19272324d252b1254627278.jpg
Edited by Graziano
1 hour ago, watchweasol said:
Hi   What a watch to produce those figures with all that gunge, looks like its had a varied life 46 years worth.  It will come up a treat  and ok for another 46 years.
Howdy , Yes my da was a carpenter all his life that watch never left his wrist . I will post up when I clean it up and service it and thanks for your input watchweasol
It's not plastic, and it's not a simple movement spacer in the conventional sense.
The "DS" in the model name stands for "Double Security" and is Certina's approach to equipping the watch with the highest level of shock protection. In the original concept this involved isolating the movement from the case using a thick soft rubber shock absorber (think in terms of a 4mm thick soft rubber "O" ring) where you would normally find a metal or hard plastic movement spacer.
I think the issue of liquefied rubber case back gaskets is well enough known, that the same thing should happen to a soft rubber shock absorber over 46 years is no real surprise. It has made an awful mess though.
    • Mark keeps a close eye on his forum. I'm sure if you asked him he will reply, he might not do it right away but you will receive his answer.
    • I kind of think the same, the surface under the oil is the same as the surface around the oil. Can epilame both repel and attract , that doesn't quite make sense in simple terms, but is it more complicated than that.
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
