Hey All
I am brand new here!  And this is my first attempt to service a movement.
What brought me here is my Vostok amphibia which is currently not working. I believe the movement to be a 2414 or a 2409.
The watch has stopped running, and makes a terrible grinding noise when I attempt to wind it. (This occurred after I removed and reinserted the stem).
Any help would be awesome!
I intend to strip the watch down clean it oil it and put it back together!
Warmest
Bradhead
Hi   and welcome to the forum.  I take it the watch was ok before the stem was removed and re inserted, For what reason was that done ? .   The fault seems as that it is self inflicted in as much that the stem/keyless work are missaligned or damaged. I would desist from continuing to wind the watch and to investigate what's gone wrong. the likelyhood is that the crown and or castle wheels are or have been displaced.  The only answer is to remove the dial and hands and observe the keyless work alignment as regards to the stem fitting and engagement with the ratchet wheel(great wheel) only then when its working ok proceed to do the maintenance.  I Have attached the tech sheets for both calibres   hope they will provide some guidence.
Wostok 2409.pdf Wostok 2414.pdf
2 hours ago, Bradhead said:
Hey All
Warmest
Bradhead
Welcome Bradhead and congrats on your choice of movement. I started out with Vostoks myself and had an absolutely amazing time with them taking my first steps at tinkering, servicing, and repairing. When new, the Ratfaced git's Vostok videos were very useful and inspiring to me. Anyway, when and if you want to get serious I do recommend www.watchrepairlessons.com. The Ratfaced git (Dan) is a self-taught retired car mechanic, and he doesn't always do things by best practice. Nevertheless useful and inspiring!
You don't have to guess about the calibre if you know it's a Vostok 24XX something. If it is a mechanical (wind-up) Vostok without a date complication it is a 2409, otherwise a 2414. If it is an automatic watch without a date complication it is a 2415, otherwise a 2416. Either way all of these movements are very similar, with the added date complication being the only difference, and most parts (with a few exceptions) are interchangable.
Now, about your watch;
Well, it's always difficult to speculate but my guess is that you didn't get the stem pressed in all the way. This is a somewhat common problem with the Vostoks. I suggest you grab the stem on the inside of the case with tweezers (or very pointed pliers) and try to press the stem into the movement the last bit as far as you can. You need to use a bit of force, but be careful. Sometimes you hear a click when the stem seats itself properly.
For spares you can pick up a lot of movements on eBay for next to nothing and then scavenge them for parts which is good and fun practice. For example: https://www.ebay.com/itm/2409A-B-caliber-VOSTOK-Watch-Movements-Altered-Art-6-pcs-415/153773928815
Good luck and please keep us updated on your progress!
@watchweasol @VWatchie
Hey!
Thank you so much for taking the time to get back to me!
@watchweasol - Yes I am resisting doing anything to it and will do as you recommended and take the dial of before progressing.
Edit: The reason for the removal of the stem was to, re seat a hand which had which fallen off.
@VWatchie - Thanks for all the on going help, will dive into the resources you pointed me to.
Thanks again!
Edited by Bradhead
The 2409 is pretty  simple  and robust, although  I confess a preference  for the 2209..proceed slowly..take pictures as you  go..be very careful  with the balance  staff . If this is your first attempt  you may very well  mess it up..luckily  used 2409 can be bought all day long on ebay or etsy for very little  money.  To do  this right  you are going to need some decent  screw  drivers and tweezers.. and a movement  holder. Economy grade is ok for starters..
One other  caveat...beware  of the JESUS  spring..small  little  springs  in the works  that fly off to only God  knows  where..when  working on or around  them  I like to put the watch inside a gallon  sized plastic bag..I work on top of a sheet  of copier  paper.. the springs  get contained and you can spot them  easily  against  the white paper.
Good luck and just proceed carefully, especially so when refitting the train bridge as they can be a very tight fit and damaging the pivots is easy.
This might help you.
Thank you Watchweasol for posting these two parts list ! :thumbsu:
Do you happen to have the parts-list for Vostok 2416b as well ?
Kind regards ...
Edited by Endeavor
Hi  It would seem so although one can transpose the names from another service sheet as I would suspect what is an escapewheel in russian is the same in German or Swiss. It is a pity that they dont put the listing in Russian but I suppose translation was a problem back then.
  • 9 months later...
On 1/30/2020 at 4:38 PM, watchweasol said:
Hi  attached a few from a vostok to give you some visual help.
I believe I recognize those pictures! ?
The OP has requested to be removed from the forum, I have no idea why as he did not state a reason - but it seems he got the help he wanted.
But the thread will remain active as the information here may still help others in the future.
    • Of course, donor movement is needed, but the balance/hairspring assembly itself can be saved. OP, You just have to use tweezers and needle to straighten and two tweezers to untwist if needed to rectify the outer coil. What is seen in the middle may be is because the stud pressed to the spring, but we will need pictures after outer coil rectifying. The regulator and stud carrier are snapp-fitted on the antishock assembly. Lift and pry them together with some sharp tool and they will come off.
    • A good learning piece but think for the price of a new movement that's all it is. Probably just transfer the rotor if it's Citizen branded.
    • I'm no expert, but I'd guess this one is for the bin. Looks like it's been tinkered with by someone armed with a hammer and chisel. When the pallet, escape wheel and balance are all damaged it's beyond repair isn't it? Or a new movement if the watch itself is of value.
    • No need for special tools. Loosen stud screw and just push hairpsring stud out of the hole.  Regulator arm is spring circled around the setting housing, insert cutting edge of a safety blade under it,  opposit ( 180 degrees) to regu arm itself, and pry  half of the circle up, you then see how it all is made at put together. Remove the mobile stud carrier as well,  reinstal in proper order, first goes on the stud carrier, second put the regulator arm on top and press it home. Exactly as nev explained above. Trueing inner coils is done when balance complete is seperated from the cock.   The part thats bent over itself. 1-Unbend hairspring as much as you can when balance is seperated, just grab the hairspring stud in tweezers , grab hairpsring with another tweezers streighten with  strokes as you  move the second tweezers  away from the stud. 2-Move stud carrier and regulator arm as wide/ apart as they go , to provide max space which comes useful in next step. 3- Fit hairspring stud, into stud carrier hole. 4- Put balance and cock ( when attached together) back on mainplate.  5- You have enough space to grab hairspring in  tweezers to shape as you move your tweezers  away from stud.
