Help identifying movement
Nikia
Hi everyone! Nicola’s here. Today I’m working on a pocket watch that my grandpa gave me, he said the watch doesn’t wind up. As soon as I opened it, I noticed the click spring on the ratchet wheel stop was missing. I still have to dismantle the movement and check out where the little guy went, however the movement wasn’t running so fingers crossed it hasn’t caused any damage.
I just ordered a mega assortment of click springs, hope I can adapt one of those.
Can anybody chime in and help me identify this movement? It doesn’t seem to have any markings on the mainplate.
It’s from a “index” pocket watch.
Here to the pic:
Uggghh i feel your pain, these swiss pocket watches can be difficult to identify. I know index was a micro brand from the West End SA watch company in switzerland, (which introduced the first incabloc in 1934) not to be confused with the West End watch CO. from Pennsylvania USA. Depending on dating this could be an FHF movement since thats what they were known to use up until the 60s when ETA became a big player. It is an incabloc so we can note its no older than 1934 and no newer than 1960. So safe to say this an FHF most likely from the 50s based on its design.
https://www.vintagewatchstraps.com/fontainemelon.php
here is some info on fontainmelon (FHF). Did you look on the dial side to see if you can see the logo, that is normally where you would find them.
FHF did make movements with some pretty angular bridges and that's some great info from @saswatch88 on Index but we might have a non-Swiss company using the same brand name here as I'd agree with @rogart63 on the Chinese origin. Here's such a Shanghai movement that looks similar: https://17jewels.info/movements/s/shanghai/shanghai-zse/
I was initially going to say it could be chinese. And i would agree that would be the case if you cant find any FHF markings anywhere.
Here to the pic:
To assist with a search the size in Ligne and a pic of the keyless side really helps to narrow down the hunt. Also be aware there were a lot of pocket watch manufactures that made pocket watches just to be sold on as un-branded so finding the calibre is really difficult. Ie I recently repaired an un-branded Pocket watch that needed a new balance staff and just by luck I found the watch on the net but it was made by Omega. I purchased the Omega balance and it fitted perfectly so job done.
I have the part . Found an old Breitling fake watch. The setting lever looks the same and so does the balance bridge. It's an automatic movement . But it has the click and click spring intact. If you want it send me a PM
Edited by rogart63
pictures
Hi, thank you sir! This forum really is a resource :)
I managed to adapt a spring I found in another movement I had for spares, stripped the movement, cleaned and oiled. Seems it works nicely now, however looks like I’m unable to adjust the beat error lower than this.
I guess I can live with that, as the movement is a cheap chinese 17 jewels!
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile and is supported by the literature:   A review on control of droplet motion based on wettability modulation principles design strategies recent progress and applications.pdf   However the hole point is that we have less mobile oil so an oleophobic  would see to be the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic (beading) and cohesive/adhesive resulting in low mobility?? This may explain the high price??
