Hello,
I'm secretly reading here for several months and now finally decided to join the forum and introduce myself :) I wear watches for several years, have and had many nice Quartz watches, but never was really into opening them until I got a watch with cheap Asian mechanical movement. It fascinated me so that some months ago I tried to dismantle and reassemble it, of course it ended up with a lost spring and 2 bent pivots :D
Nevertheless I want to learn more and plan on getting better tools and hopefully starting new projects, so I'm glad to join here !
Many greetings to all from Germany !
Welcome here! I'm noting your posting as a witness for the people which periodically show up here with the declared intention of repairing their expensive Rolex, complicated chronometer, or unreplaceable heirloom piece, based on their previous experience being a mechanic, or "very handy at things", that of course without any specific tool. But I'm sure you will accomplish many successful repairs, perhaps with the help of the great training by our Mark Lovick: watchrepairlessons.com
Thank you both for the kind welcome!
:DI only did, knowing that a whole replacement was about 15 bucks, crazy that there are really beginners thinking about taking apart a Rolex in pieces lol
By the way, love the youtube channel of Mark, a really great guy!
Hi BiH  welcome to the forum, You would be surprised at what they dismantle and spend hours looking for bits on the floor.  Fond memories of Germany,   Moenchengladbach, Erlelenz, Willich and Wuppertal working on the military bases, long gone.
Hello,
I'm secretly reading here for several months and now finally decided to join the forum and introduce myself [emoji4] I wear watches for several years, have and had many nice Quartz watches, but never was really into opening them until I got a watch with cheap Asian mechanical movement. It fascinated me so that some months ago I tried to dismantle and reassemble it, of course it ended up with a lost spring and 2 bent pivots [emoji3]
You came to the right place with like minded fanatics! Welcome!
    • No need for special tools. Loosen stud screw and just push hairpsring stud out of the hole.  Regulator arm is spring circled around the setting housing, insert cutting edge of a safety blade under it,  opposit ( 180 degrees) to regu arm itself, and pry  half of the circle up, you then see how it all is made at put together. Remove the mobile stud carrier as well,  reinstal in proper order, first goes on the stud carrier, second put the regulator arm on top and press it home. Exactly as nev explained above. Trueing inner coils is done when balance complete is seperated from the cock.   The part thats bent over itself. 1-Unbend hairspring as much as you can when balance is seperated, just grab the hairspring stud in tweezers , grab hairpsring with another tweezers streighten with  strokes as you  move the second tweezers  away from the stud. 2-Move stud carrier and regulator arm as wide/ apart as they go , to provide max space which comes useful in next step. 3- Fit hairspring stud, into stud carrier hole. 4- Put balance and cock ( when attached together) back on mainplate.  5- You have enough space to grab hairspring in  tweezers to shape as you move your tweezers  away from stud.
    • Probably more than you need to know in these two vids, but sharing because I found them quite interesting. 🙂
    • And then the problem of the stud holder and regulator which are on the wrong sides of each other:   I am baffled as to how this will have happened?  They can't re rotated into place, the regulator pins stop the spring stud from moving past. I don't think I can remove the regulator and/or spring stud without a staking set?
    • Just to inform that this is not a shock protection, just end stone fixed in place by the spring.
    • I had the privilege to be put on secondment to RR Ansty just outside Coventry to help design and build a power station at the old Fort Dunlop site in Birmingham. The sound of those Trent engines when they fire up is something to behold.
