Hi everyone,
I've been stripping/cleaning/reassembling a Seiko 6309A movement.
I'm new to this, so mistakes were made. During reassembly one of the stones on the pallet fork has detached.
This leaves me in an awkward position, as I doubt I have the skill to re-attach it and according to cousins, this fork is obsolete.
I've seen replacement forks from abroad on eBay, but they are expensive. Does anyone know where I could get one in the UK?
Thanks!
3 minutes ago, vext01 said:
Thanks. Looks like this site has the part, but do I see it right that it's  €11,95 postage to the UK?
Read below: "Small orders below 25 euro can be send by regular mail (€ 2,95). It takes longer!"
I can vouch for speedtimerkollection, used him many times and no hassle. For clarity I’m not involved in any way, just a happy customer.
Ps: you could always learn to fix it yourself?
Yeah, I could, but I think re-setting the pallet stones might be a bit advanced for me at this point in time.
7 minutes ago, Nucejoe said:
I get new unused complete fork, new pallets breath life to the escape mech.
Very hard to get new parts for a 50 yrs old mov't like this.
Schillachi61  has new forks. But cost 9.99 . He is in UK so  won''t be that much shipping . I  have his email adress if you like.  Maybe  a couple of quids cheaper? Send me a PM
Or keep scouring the bay and you may find a movement you can cannibalise. But that movement may have unseen issues meaning you’d be back to looking. Or if you’re like me it’d just mean you have two movements you want to fix instead of one! [emoji23]
11 hours ago, vext01 said:
Hi everyone,
Thanks!
First and foremost lets figure out why did the stone come loose, how did you clean the movement and what solutions did you use?
gunna be almost impossible to find a NOS one if one is found it will cost about as much as a complete movement or even a complete watch will cost. So you have to make a choice on which route you wanna go.
Keep in mind Seiko pallet forks are mostly interchangeable. off the top of my head a pallet fork from a 6106, 6119, 7002, 7009, will work as well and there are others.
Luckily someone on Facebook has offered to send me a spare! I can't believe my luck.
As for cleaning.... Bear in mind that I'm very new to this and I'm operating on the cheap until I know this is a hobby I want to pursue...
For most of the movement I used first a weak solution of dish detergent, then a wash in IPA alcohol, before a dip in a final uncontaminated pot of IPA. However, I did not clean the palette fork at all, because I read in a book that the adhesive used on the fork breaks down in solvents. (I also didn't clean the balance for fear of breaking it).
I know that ideally you'd use professional solutions and machines.
The stone actually came loose as I was re-fitting the bridge. The watch suddenly let all of it's power out in a great "whiiiiz". Perhaps I shouldn't have had power in the spring whilst fitting the escape bits?
Ah! That's good to know. I did look at a spare fork I have from a fake 7S26, but it was visibly smaller.
never had A pallet stone come loose in that manner. Could have had a bad cleaning previously. You def. cleaned it correctly by not using the IPA on the pallet and the balance.
You should not have power in the spring until you have everything installed up to the pallet fork, in my case i dont wind it until the balance is installed. But either way none of this would have caused stone to come loose, so its anyone’s guess why it did. And Yes The 7s26 pallet is different.
8 hours ago, vext01 said:
Thes stone actually came loose as I was re-fitting the bridge. The watch suddenly let all of it's power out in a great "whiiiiz". Perhaps I shouldn't have had power in the spring whilst fitting the escape bits?
I think what happened is that you fitted the pallet fork with a stone over a tooth, maybe even positioned its bridge, then wound the barrel, somehow the pallet was able to hold power for a while before the stone was dislodged while tighteining or being hit by the spinng escape wheel.
Personally I find fitting the fork pallet a very delicate task and have had some breakage while doing it, we aren't all born master watchmakers! One must be 100% sure that both pivots are in place before tightening the bridge, for that observe the stones correctly engaging teeth, and the bridge being level. Only then wind the barrel to try the fork flipping when slightly touched, which is a correct procedure.
Regarding your cleaning procedure it is not necessary to use expensive solutions and machines (even if you can read some insisting advise to the contrary), but use of dishwasher soap for the movement is kind of unheard, better would be petreoum ether to dissolve old oils, followed by demineralized water, and then IPA.
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
    • At the moment I have neither EDTA solution nor Evaporust, so I tried with a citric acid solution. This gave satisfying results for most of the parts, except for the ones that are really heavily corroded. I will see whether I can acquire one EDTA or Evaporust and try that next.
    • This guy (Minimachining) has a playlist of him setting up and using various attachments on his Sherline lathe.   I know nothing about CNC machines but had a question about making screws. Watchguy.uk has a section on his website where it allows you to enter parameters for screws and wheels and then 'generate code'. Is it as simple as that sounds, can you 'tell' the CNC machine to cut you a screw (or stem) by giving it the code for a particular screw or stem and it happily makes one for you?
