Took a while, and several partial assemblies and disassembles. But it’s finally done. And running surprisingly well for my first wrist watch.fae47cba67c859f9e48edddb0053f441.jpgc76b044cf85f9daa8a738511f3742aea.jpg3fff093dc42548e789530efb5a1e40f9.jpg
:Bravo:    Looks stripped down enough to have recieved a good bath, did you brush clean too?   Cute watch too.
Very good job! I've never seen such an amplitude on a Seiko movement, are you sure you had the correct 52º lift angle on your timegrapher?
It's very good value, likely taken a full wind, but not exceptional
Note that 7S, 4R and 6R all have 53° lift angle, check attached. 52° is the machine's default, and produces a very close amplitude value anyway.
 7S26C.pdf7S26C.pdf
Edited by jdm
I'm checking your attachement, doesn't it say 52º?
Edited by aac58
As I said, that's a very good job. Honestly I've seen (and got) amplitudes above 300º but in older manual Seiko movements as 66.
9 minutes ago, clockboy said:
Adjusting the lift angle on a Timographer only makes a marginal reading difference IMO
So, why do we care about it? And why I was corrected only a few minutes since I said it should be 52º and not, for example, 54,5º as in 6119 or 6309, which is a considerable difference?
Edited by aac58
Yes it does and I believe by good chance I posted the oddball tech sheet which has a wrong value. Attached three different version which say 53º. But as mentioned, it's not a big deal of difference at all.
 917_Seiko7S26A,7S36A.pdf
NH25.pdf
7S26B_36B.pdf
Not sure what “brush clean” means. I use an ultrasonic with L&R cleaner and rinse solutions. Then is peg wood to get the remainder. I had to order a couple extra balance completes as it did not come with a working balance and I ruined the first one with a slip of my tweezers. At $4 each, I ordered 5. Went through 2 before I got it right.
Yes. It was set to 52 degrees. But that amplitude was only a in one position. The rest ranged from 240 to 260. Enough to be satisfied for my first wrist watch.
These were the Chinese ones. Very good result then, another member reported that the one he got had a bent pivot.
These are outstanding results, congrats.
I ordered from the Seiko part site from Japan. Maybe I’m wrong on the price. But not by much. Oh well, it worked. I’ll look more closely next time I order a new part.
Please post link?
I can’t find the original site. I’ve purged my browser history for government spying reasons....
However, here is a pic of one of the “extras” I purchased. I believe you are correct about it being Chinese. Though I do remember the ship-from address to be Japan.26b9433a932beeda728610c6e3b59584.jpg
Yes, also because the writing is in Chinesem and a genuine Seiko balance packaging is quite different.
Nothing strange that it comes from Japan, they trade with China just like we do and probably since a longer time :biggrin:
Edited by jdm
