First go with a Kommandirskie
Just started on my first attempt to restore a Wostok Kommandirskie. Winding stem broken but crown still around with remaining stem in the crown.
The 2414 movement appears to be in surprisingly good condition and the casing should be ok with a bit of cleaning and polishing.
But...when searching for a winding stem all that show up seems to be kind of ”integrated” stem and crown.
Are these generic to fit all kinds of casings?
And how does these screw-down crowns work? I suppose there must be space for the stem to move in when the crown is screwed tight?
Grateful for some advice from some of the guys with a special interest in these russian wonders!
It's kind of a slip  clutch set up.and the length is determined  by the case.for the  most part all komandirskie cases are interchangeable. You can order new stems directly  from meranom. Fixing old ones is not practical.
Edited by yankeedog
So the stem moves in/out inside the crown with a slip/lock function to allow for the screw down action? Makes sense.
I checked briefly the supplier you mentioned but couldn’t find any stems. Maybe I need to contact directly.
And there’s an overwhelming number of styles and casings still in production.
Any idea what mine could be called? From my point of view it looks like one of the more common with its 2-coloured bezel dots.
If the supplier is easy to communicate with, I guess I can send him a photo?
Are they easy to deal with, from your experience?
go to meranom.com, click on shop, click on komandirskie classic parts, you will see it. it is listed as a crown.it will set you back a whole $3.00 US..It ought to fit, but even if it does not. it's not a loss to cry over.I do believe they will answer inquiries. for not a lot of money you can get a new case
Edited by yankeedog
I believe  the komandirskie  stem is of the same type as the amphibia.  Is has a loose and wobbly  feeling  about it.it is normal  for the type..supposed  to stop shock  from being transferred  to the movement.  To me that sounds like hype.
Edited by yankeedog
There is alot of mechanical  incest in the amphibia / komandirskie  lines ..biggest  differences are stainless vs plated case on komandirskie..thicker  crystal  / case back and fatter gaskets on amphibia. All dials and movements  will  pretty  much  swap  out provided you have a back that  will  accommodate  a rotor on an automatic and the correct retainer ring and stem. I am pretty  sure that all komandirskie  with 24xx movement  use the same stem while amphibia  stems vary in length  according  to case type. I may be in error  of course  .but this is my understanding  . The 22xx are another  animal  entirely.  The dials will not interchange with the 24xx and the stems have a different  business  end and do not interchange either.you can however  retrofit a 22xx into a 24xx case provided  you have correct stem and ring. Case crown threads being the same. Earlier  komandirskie  did not have a threaded crown..I think they got them when the transition  from 22xx to 24xx happened.
Edited by yankeedog
Thanks for the added discussion. I mailed Meranom and had a quick response that the offered stem likely work but no guararantees. Sounds reasonable enough to take the chance for 3$ :)
Beginning to realize that these watches are both simple and complex at the same time. But it’s fun that the Vostok factory is still producing in spite of decades of turmoil. And the brand characteristics is maintained.
I will start to service my 2414 movement, order a new stem and try to make a wearable watch out of it.
19 hours ago, Ruairidh said:
That would be a sensible idea as although a very rugged movement the one found in the amphibia has a habit of being very inaccurate.
I am not  too crazy about the 24xx series. I think the 22xx series  is simpler more accurate  and more robust. It is very  much like  their  2809 but smaller  and built  to looser specs.
Hi again...
Got started on servicing the 2414 and immediately ran into a new problem.
Turns out the centre wheel shaft, driven by the main spring barrel has come loose from its wheel and no force is being transitted further to the wheel train. The wheel still sits securely on the shaft but spins freely.
Never experienced this problem in any movement before.
The attached photo shows the splines like arrangement that I presume is supposed to ”bite” into the wheel brass to secure it.
Would the appropriate thing to do to use my staking set on those shaft splines like teeth and hammer away (well not really...) to secure the wheel?
Think I managed to tighten the grip on the wheel with some light tapping in the staking set. I guess I will see if it holds up...
There seems to be a few people offering scrap movements for spares on ebay but not at all as many as one can find with some of the more generic ones.
Meranom was helpful and replied back quickly on my crown/stem enquiry. But apparently he doesn’t accept orders below an amount that makes the 3$ plus postage, customs fee etc.spin off to a lot more than I paid for the watch to start with.
Have a box full of Vostok parts if you need anything bsoderling. I need a crown for a Vostok swing lug i am about to service . Have a few contacts that could have that . Maybe they have a crown for you watch also . I  bought  parts from Ukraina . They sent it from Holland . So was inside EU . I think they have crown. I shall see if i can find it .
42 minutes ago, vext01 said:
Sorry to hijack the thread, but has anyone ever encountered a service manual for these Vostok movements? Even if they are in Russian language, even the diagrams would be of help.
Thanks
Strictly speaking you should start a new thread, however this link may help, not strictly a service manual, but in some ways every bit as good.
https://forums.watchuseek.com/f54/vostok-caliber-2414-service-notes-very-long-many-pics-226237.html
.. and of course, Mark's video is an excellent resource too.
A search of Watchrepairtalk will give you more useful tips.
Oops. My apologies. Next time I will.
That is indeed very good! Thanks for the link!
Until now I've been using youtube videos, but I find it's also nice to have the service manual on-hand. I've been unable to find any for vostok movements.
There are some manuals available, but there doesn't seem to be one source for everything. A bunch of useful stuff is here -> https://forums.watchuseek.com/sitemap/f-54.html
If you want USER manuals you could try here -> https://www.russian-watches.info/russian-watches-user-manuals/
.. but who ever needs a USER manual :D
Finally, a bunch of Russian watch sites... https://forums.watchuseek.com/f54/russian-watch-links-interest-13891.html
Google translate may be required unless your Russian language skills are up to the task.
Edited by AndyHull
Hi all,
Just wanted to wrap this one up and show where it ended.
Finally decided to purchase the stem/crown from ebay seller ”bestrus” who was able to point me towards the correct item for the somewhat older style casing I have. He even threw in an extra free dial that looks ok and may come handy at some point.
Only the yellow crown available, these are apparently getting quite rare.
Rivetting the wheel onto the stem (that this thread started with) seems to work ok. Came loose once and had to redo the operation with a bit more force. Crossing my fingers it will stay put...
M/s turned out to be broken but found a close enough one in my small stash that gives an amplitude up around 300 degrees, fully wound.
Picture attached. Nothing fancy and a bit rough around the edges but quite ok as a start and I will definitely keep my eyes open for the next one.
    • You would always get an answer John, you dont need to be dramatic or humerous to get one, but it was appreciated anyway 🙂 Kind of, for those of us that wish to stay in touch and continue to learn from each other in case the forum ever dissappears then yes i suppose so . I  hope that you would also count yourself in , what we learn from you is invaluable,  how you benefit from that exactly I'm not sure, being able to teach ?
    • While you might have seen it as a humorous/Dramatic remark was done very deliberately so I could get an answer. Let me quote myself? The simplistic of this entire discussion is the group would like the last forever.   If you go to the top of the discussion group you'll find something to click on that says staff. Then you click on Mark's name and you find out interesting things? For instance he was last here on Saturday so yes he is here. If there is a crisis or a problem he is going to be here. You will also find a list of his activity although that's only the public activity. There's a lot of work that goes into running message boards and he probably does a lot of stuff in the background that we don't see to keep it going. Unfortunately message boards do not run themselves. Then regarding this did you notice you can message Mark and ask him. Then if somebody, we could elect somebody from this discussion such as @Neverenoughwatches To reach out I would really keep the message super simple like? You could refer him to this discussion but I would really keep it simple Like for instance the group enjoys his message board and what could we do to keep it going Forever? Then regarding all of the other suggestions comments helpful remarks or ideas? When was the last time any of you bothered to read the message board rules? This is covered which is one of the reasons I did the dramatic things I did to provoke a response of the basics as opposed to starting to suggest or seemingly suggesting all sorts of ideas which are covered by one of the rules found in the section on rules. In other words I'm going to quote something from the rules of the message board.
    • For me any input from Mark would be great. If he's keeping a close eye i would imagine he has read about our concerns here. But specifically i would like to know if he is ok with us collecting each others contact information for those of us that wish to provide them.
    • Thank you!   Yes I did. I did not notice a difference. Although 9415 is advertised as a thixotropic grease (and I did had high hopes for it), the only advantage at this point I see is that its “easier” to apply than an oil (if one does not use epilame). But this is subjective, I guess. What I did notice though, if you apply a bit too much grease, that definitely slows down the movement. Oil in this case is a bit more forgiving, as its super thin, and it would usually just spread out.  Again, imho.
