What is this tool used for?
VWatchie
URMAKARVERKTYG
It's probably more than 50 years ago, but I still vividly remember this tool being in a drawer at my grandfather's house when I was a kid. I had no idea what it was or what it was for but I was for some reason intrigued by it and played around with it. I think I asked my parents what it was and they had no idea so, being a kid, I guess I didn't think it was any use asking my grandfather.
So, can anyone please tell me what it is and what it is used for? Thank you!
I agree with Tmuir, it's a glass cutting tool. First, you scribe the glass with a sharp and hard edge (like an industry diamond) and then you put your tool on the edge of the glass into any of the two cut outs in the tool depending on the thickness of the glass and rotate the tool so to "bend" the glass and hopefully the glass will break were you scribed it.
    • Couldn't see it on the tech sheet , picture is a bit fuzzy though . Is that to keep the pinions pressed on Marc ?
    • Doctor, If the train turns when hands setting, this means that the train is not blocked. And this is true for all kinds of trains design. The train is normally blocked by the lever. So, put the lever in place and try again. If the train turns again, search where You have placed some wheel upside down and it is not meshed with the next one in the chain. The other thing is the amount of friction that is needed to overcome when setting hands. Yes, the friction part here is in the great wheel, and it needs lubrication. If the parts are dry, then friction will arise, seizing will happen and thus risk of breaking of teeth in the train or breaking of joint wheel/pinion. I don't know this calibre, but I guess the clip is part of the friction device. But for sure it stays tilted, which is not normal. So, pay attention to it and see what is wrong there
    • It most certainly should be there, but it should fit better than that. Here is what it should look like.
    • This way is dangerous. The problem is that the collet is not expected to be perfect in this tool and the wheel used for the grinding is big and easy can touch the balance wheel. Can You show the bottom side of the balance wheel?
    • It shouldn't be attached    The pinions look independent of each other, not in alignment,  but the clip is bothering me or have you just placed that on the pivot end?  Found a cannon pinion maintaining clip in the tech sheet, is that the disk on the end and is broken.  Whatever happened to exploded diagrams 😠
